Question about Kenmore Washing Machines
Have error code F dl what can i do to fix this
  • 5,911 Answers
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot this problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
For a full explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Posted on Nov 14, 2010
What does F --DL code mean
with out a make or model number I think this code means problem with the door lock
https://www.hunker.com/13410537/how-to-fix-a-dl-or-f-error-on-a-whirlpool-duet-washer
https://www.youtube.com/watch?v=_BsaIsSlxNY
May 29, 2018 | Washing Machines
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Quiet Pak 4 front load washer. I keep getting the DL and F11 error. The door is locked and won't open and the cycle will not continue. I can hear a small clicking noise in the...
f11 eror is a serial coommunication error check the harness wirinbg tio the motor and cpu unit
check the drive system for worn part
check mcu motor the dl error fial code is for door lock error it will try to lock 6 times before error code is displayed that is the issue see repair clinic.com for help hope that helps
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
