Question about Danner Pond Pondmaster 250 Gph Mag - Drive Pump
Wher does the o ring go on my pump? I cleaned it & didnt even realize it had an o ring til now
  • 565 Answers
The O ring goes between the impeller housing cover and the pump. Remove the 4 screws and pull the housing cover off and you will see a thin groove that the O ring fits into.
Posted on Nov 21, 2010
Washing cycle timer display slows/stops
sound like the pump is at fault still it might still work but it sounds like its an earth fault with the pump but some time by replacing it don't all ways work its normally the board at fault as well an expensive job OK
Nov 03, 2012 | Whirlpool AWOE8748 Front Load Washer
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
Idisconected my battery for water pump have after market radio didnt think it would be a prob. but it turns over and will not start it has built in alarm and indicator light flashes rapid is there a way...
Insert ignition key,turn forwards to run. Just till red lights & theft/alarm light goes on. Do not try to start or engage starter.Leave on till light stops flashing. It may take up to 10 minutes. Once light stops flashing turn key off. Then start car & let run for awhile.
Mar 21, 2011 | Pontiac Grand Prix Cars & Trucks
7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Jul 12, 2010 | Briggs & Stratton Garden
How do you reset wii remotes when you have put new batteries in
under the battery cover there is a red button to push, there is another on the wii console that i just realized i didnt state in a few other post. push 1 then the other and visa versa til they work again
Apr 11, 2010 | Nintendo Wii Remote Controller
My amp settings was all the way up...and i didnt even realize it... i messed up 2 of my 15s pyle drivver subs...is there any way i can open up the sub and fix it up or something? appreciate it if someone...
If your subs quit working then chances are you fried the voice coil and while anything can be repaired it most likely isn't worth the money you'd pay to have them fixed.
Nov 26, 2009 | Car Audio & Video
1992 Dodge D-150 318 Magnum runs erratically, stalls til warm...
Replace the acceleration pump. It's a small diaphragm on the carburator, near the fuel line. Usually less than $10.
Aug 07, 2009 | 1992 Dodge Dakota
2004 grand jeep cherokee won't start
must likely the fuel pump and the fuel line need tobe clean out. it may have **** up all the junk that is on the buttom of the tank.
Good Luck!
Dec 12, 2008 | 2004 Jeep Grand Cherokee
AT&T Model#972 How to lower ringer volume?
Hey how are you ??? sorry I didnt see your post til today I'm supridse no other experts didnt reply to it :(
Any way here is your user manual
http://qwest.ettp.net/reference/ATT%20Model%20972%20Manual.pdf
and to solve your problem
When not on an a
call press a LINE
button, then press
VOLUME + to
increase,VOLUME
- to decrease
volume of the
ringer for that line.
View manual for details.,,,
And again I apoligise for the late reply Sir ,, I do hope all is well with you .. Regards
Jan 06, 2008 | AT&T 972 Two-Line Memory phone
Danner Pond Pondmaster 250 Gph Mag - Drive Pump Logo
63 people viewed this question
Top Danner Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Danner Garden Expert? Answer questions, earn points and help others
