Question about Whirlpool Duet GHW9150P Front Load Washer
F6 Fault drum won't spin - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
"F6" is a Motor Speed error code. This is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), and/or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Nov 14, 2010
1999 Honda F6 C Valkyrie starter spins but won't engage
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
starter spinning not engaging flywheel Honda Tech Honda Forum Discussion
1999 GL1500 starter won engage GL1500 Information Questions goldwingdocs...
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Jun 25, 2014 | 1999 Honda F6 C Valkyrie
Asko 20004 washes but won't spin
This is a motor fault issue. As I don't know your ability in repairing or what tools you possess. Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes. There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting. This is not complex just dirty I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
Nov 18, 2013 | Asko Washing Machines
Washer comes up with error f6
The F6 error on a Whirlpool Duet means that the control unit doesn't know the drum RPM speed during the spin cycle. It occurs with a number of problems. The problem could be with the MCU (motor control unit) or the wiring between the motor and the MCU. Next you should check the wiring between the MCU and the CCU (main clock). A problem with the door lock or that wiring could also cause the issue. Finally, the bearing on which the drum spins is bad.
The MCU is the most likely faulty part unless you find a wiring problem. (The wiring harness has a number of small wires connected to it; it's not uncommon for one wire in the group to break while the rest are intact.) Inside the washer's front panel, there should be a wiring diagram with additional information on some diagnostic steps.
If you can't easily spin the drum by hand, then the bearing is a likely suspect.
I hope this helps.
Oct 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
My washer shakes real bad when spinning and makes a rumbling noise
You washer drum is running eccentric and so there is violent action while it is spinning in the cycles of wash and spin.
The fault gets unbalanced when the spinning cycle is ON as the clothes loose the weight of water and needs a stabilizing with a damper/suspension system.
Hence a fault in the suspension of the drum can be the element of fault. You will need to check if there is friction in drive system, check for free movement of the shaft.
Make sure the dampers are not faulty if so replace.
Finally check if the spring suspensions have gone out of the frame , changed or shifted.If so realign the springs to have the drum in the center.
Nov 17, 2010 | Washing Machines
Motor Fault
check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Apr 25, 2008 | Asko W6021 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
