Question about LG DLE2516 Electric Dryer
I forgot to place lint filter in dryer, dryer sheet got sucked in, dryer made huge clanking sound, stopped working, still had electricy, burnt smell near dryer
    Problem Solver:
  • 6 Answers
It sounds like the sheet was pulled into the fan of the blower. You may need to take the dryer apart to remove it. If you can still see the sheet then you can try pulling it out but I would turn off the breaker or unplug the dryer before doing that.
Posted on Jan 07, 2015
3 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: dryer stops and won't start again
hi
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Posted on Oct 12, 2008
  • 4088 Answers
SOURCE: Brand new dryer. **** went down lint filter area
You may have to remove the front panel to enter the air passages and blower fan. Try feeding a vacuum cleaner hose (remove the metal hose end) into the area behind the filter to see if can pick up whatever dropped into it. Hope this helps!
Posted on Apr 12, 2010
It sounds like something clanking and starts to smell
Turn your vacuum over and look where the brush is, there could be several things wrong with it but you should be able to locate the problem here. It sounds as is you sucked up a penny or rock or something hard hence the clanking. The smell is either the object in questing is getting stuck by the brushes and creating a smell most likely a burnt rubber smell I would assume.
Nov 09, 2012 | Vacuums
I suddenly have the smell of urine in my dryer. Nothing was washed with any urine residue. I always double rinse each load and often use a little bleach with my "white" laundry. A couple of...
The only thing that I can think of that could produce a urine/ammonia smell is a shorted capacitor that is leaking. But normally when that happens the dryer motor will not start.
Jun 17, 2011 | Dryers
My dryer smells like it is on fire.
This is a sure sign you have airflow problems in your dryer.
1. Check all of the ducting from the lint filter.... all the way THROUGH the outside wall for signs of blockage / ANY lint build up.
2. Check airflow at the dryer exit by removing the duct connection. The airflow should push a relaxed hand away from the dryer vent connection.
a. If it does not do this the problem can be
1) Excessive lint inside the dryer ducting
2) Lint filter clogged with dryer fabric sheet material (wash with vinegar and water then soap and water)
3) Area around lint filter blocked / restricted by lint
4). Broken blower wheel.
Until you resolve this problem: I highly recommend you stop using your dryer as it really can catch fire.
Thanks for choosing FixYa
Kelly
Oct 06, 2010 | Dryers
Lint filter light comes on and smells like smoke from inside the dryer. No lint in lint filter
You need to vacuum the lint from the entire vent system from the door to the outside vent. Wash the lint screen in hot water and detergent to remove fabric softener sheet residue which plugs the screen.
Sep 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer will not dry clothes in single cycle, and towels smell burnt why?
Check the entire air vent system for lint obstruction. Remove the lint filter and wash in hot water and detergent--fabric softener sheets will build deposits on this screen, which restricts air flow.
Sep 07, 2009 | GE DBSR453EBWW Electric Dryer
LEQ1442ES--Nasty Smelling Clothes--Major lint inside
They make a 'air vent' lint cleaner and there is a handy brush made for cleaning your fridge coils that would work great. After you clean it, toss a 'Bounce' dryer sheet in to freshen it up!
Jul 08, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer stopped working after 2-3 minutes
Go out and buy you a duct cleaner. It looks like a dome shaped broom. Clean your duct from the outside and if you can from the inside. Also if you use fabric softener sheets, clean your lint filter with soap and water periodically (every 3 months would be optimal) to remove the clear residue the dryer sheets can leave behind.
Good Luck!
Apr 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Burnt smell in dryer
Open the service panel and check that the heating element is clear from any lint on it. Be awre you should unplug the power cable before touching the heating element. Good luck!
Sep 01, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG DLE2516 Electric Dryer Logo
124 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
