Question about Dynex 32 in. LCD Flat-Panel HDTV
The guide button on my remote (Dynex) does not work. Everything else is working fine. Do I need a Dynex code number to re-program the device.
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
I went to the DYNEX website and found universal remote codes. http://www.dynexproducts.com/universalcontrolcodes.aspx
This fixed my problem between the direct TV remote and my 42 inch DYNEX plasma. There are codes for different models as well.
Posted on Jul 29, 2008
SOURCE: Need code to operate Dynex Flatscreen TV on Verizon Fios
The code is 0490
Posted on Aug 03, 2008
SOURCE: progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Posted on Jul 10, 2009
SOURCE: dynex code for Charter cable remote
I need the current codes to program my remote control for Dish Network
Posted on Jun 17, 2010
SOURCE: I need the dynex tv code for a comcast remote control
10463 still works; 32" Dynex bought last week December 2010
Posted on Jan 04, 2011
I have a ge universial remote i need the code fora dynex flatscreen tv dvd combo
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device Button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below. Codes for brands are located at the bottom of this link. http://www.directutor.com/content/ge-universal-remote-instructions
GE Universal Remote Codes and Instructions direcTutor
Nov 15, 2016 | GE Televison & Video
I have the uiversal remote 3 control to prgram the DVD on my dynex tv 24 inch tv which has a built in dvd. None of the codes i put works help me please!
Not all universal remotes will have ALL codes available to program---they are truly NOT UNIVERSAL.
That remote just may not be able to do this.
Apr 11, 2012 | RCA 3-Device Universal Remote
What is the tv code for the 40 inch dynex tv?
The code 135 should work. If not, try the code search function:
  1. Turn on the device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button)
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Aug 03, 2011 | Innovage Jumbo Remote Control
I lost my code sheet. how do i get a new one.
Try to do this:
Guide to Programming the Remote
Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
SOURCE
Sep 29, 2010 | Innovage Jumbo Remote Control
I need a remote code for a Dynex tv for dishnetwork remote for a 32 inch tv
We would be happy to help you with getting your DISH Networkremote to control your Dynex TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Dynex TV; here some of the codes we currently have: 538, 720, 115, 834, 507, and 445. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Aug 10, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have lost the ge universal remote guide for the codes its a ge sku 24914 universal remote i need the codes to program the remote
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
Jun 13, 2010 | Universal Remote Control GE174Universal...
I need the codes to program my Innovage Jumbo Universal Remote for Dynex television
As there are no specific codes for the Dynex TV you have the choice of either using the Auto or Learn method. The following are instructions for both:
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. *
Mar 02, 2010 | RCA RCU600M Remote Control
Dynex tv code
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
Feb 27, 2008 | Televison & Video
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Apr 01, 2007 | GE RM24911 Remote Control
Dynex 32 in. LCD Flat-Panel HDTV Logo
134 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
