Question about Sharp Televison & Video
How do I reset the 52" TV to original settings. Screen is on Widescreen permanently
    Problem Solver:
  • 11 Answers
Could you please post exact model of your sharp tv. however i will give you this generic solution. In order to do this, you'll need to have your remote handy. You cannot reset the television using the control panel.
  • Turn your Sharp television on. Press the "Menu" button on your remote control. Press the "Right" arrow until you see "Setup."
  • 2
    Press the "Down" arrow until you see "Reset" displayed under the Setup menu. Press "Enter."
  • 3
    Type your secret four-digit code using the remote keypad. If you do not know it, you'll need to reset it by following the process in the section "Resetting the Parental Control Password." After you type in the code, "Reset to Factory Preset Values" will appear on the screen.
  • 4
    Press the "Right" arrow to select "Yes" then press "Enter." The screen will show "Now TV Will Restart." Press the "Right" arrow then press "Enter." Wait for the television to reset and revert to the factory default settings.
  • Posted on Nov 14, 2010
    Our 52" lcd was installed with a Bose surround
    Tries tv and Bose audio system unplug,replug it back like an hour later.Both systems now,should be resetting itself back to the factory setting.Should work normal now.If still have the same problems.The tv Tuner signal board is having problems and dying.
    Nov 08, 2010 | Samsung LN52A850 52 in. LCD HDTV
    Our 52" widescreen LCD TV just quit working.
    This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
    Apr 09, 2009 | JVC HD-52G787 52" Projection Television
    Sanyo HT30744 Aspect Ratio Help
    Do you still have the original remote? If so there is a button that says "Pix shape" that will change your aspect ratio for you. If you are watching something in HD it should say "full". If it is analog it will say "normal" in 4x3 format. If you want it stretch hit it till it says "zoom 1" or "zoom 2". If you don't have the original remote I am not sure how you would change it. You can find them on ebay if you need one. Hope this helps.
    Jan 30, 2009 | Sanyo HT30744 TV
    Magnavox 52" widescreen 2003... When you turn it on it takes abou
    If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
    Screen shrinks and expands - may or may not correct itself after the TV warms up.
    After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
    Philips 52" LCD TV
    I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
    Aug 21, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
    Zoom control
    Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
    Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Widescreen
    Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
    Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
    Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
    Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
    Hope this helps.
    Matt
    Feb 29, 2008 | Philips DVP3020 DVD Player
    Display appearing stretched
    the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
    Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
    Bowlike effect convergence all screwwed up
    I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
    Mar 10, 2007 | Mitsubishi WS-65819 TV
    Televison & Video Logo
    523 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
