Question about Navigon 2100 Portable GPS Receiver
I have a problem my navigon original charger broke, and iam using a USB charger and the computer symble comes up, i tried to buy 1 at navigon .com but USA cant shop for accesories, please help me getting a model that i can buy to use as a carger and to be able to use my gps in the same time thanks a million
Same thing happened to me. Hope someone can solve this problem.
Posted on Jan 23, 2011
Ineed a dc5vv2.0a that came with it I get other for it and do'not work and the usb is not work if did not come with the moblenab12-nv7a please help
If using the supplied / original BLACK and WHITE USB cord, the black must be used for charging. The white is for data transfer only and lacks connections for power / charging.
Most USB chargers will output 1 amp or less. Many USB jacks on computers output between .5 and 1 amp - max. Your device calls for a charger with 2 amps output. Connecting to devices such as those mentioned above can overload and damage the charger or computer - don't use them!
USB ports have standard connections or "pinouts". You should obtain a USB charger (5V DC) rated for 2 amps (or more for better performance). Be sure to select one with matching USB connector (compatible with your device) - mini, micro, etc.
Amazon has several from which to choose:
Amazon com nabi2 nv7a charger
Nov 12, 2015 | Nabi 2
Navigon 70 charging trouble
The battery probably needs to be replaced.
Mar 04, 2014 | GPS
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Mar 23, 2010 | Navigon 2100 Max Portable GPS System
How do I give my brand new Navigon 3300 a good overnight charge
if you have a pc, you can use the usb to mini jack and it will charge
Mar 09, 2010 | Navigon 3300 Max Car GPS Receiver
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
Can my NVG5100 be used for navigation when charging
it should be able to. i have a garmin and it will work while plugged in.
Dec 03, 2009 | Panasonic Navigon 5100
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 2100 Portable GPS Receiver Logo
244 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
