Question about Whirlpool CAM2752KQ Top Load Washer
When you turn my top loading washer to spin cycle, it starts spinning so hard, it begins beating off the inside walls of the washer. I'm not sure if it is supposed to be bolted down or what.
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
watugot
  • 290 Answers
SOURCE: Final spin cycle for kenmore 417.40042990
This is an interesting problem. How long does it have to sit before you can get it to spin? Can you let it go through the cycle and then immediatly put it into spin and it work? This machine will not spin until the pressure switch senses the water has drained. So you could have a slow drain, a clogged pressure hose, or faulty switch. A clogged hose or faulty switch would usually cause it to fill with more water than normal also. A slow drain is most likely, check the drain hose when it is draining and see if it is putting out a strong flow or just slowly draining. I think you will find it to be slow. This will cause it to take up all or most of the spin time trying to drain the water. If it is slow draining, check the pump for a sock or some obstruction. If the drain is good, remove the top and remove the rubber hose from the pressure hose and blow through it. You should be able to blow through it easily. A restricted pressure hose will cause the machine to think it has water in it after it has drained.
Posted on Oct 05, 2007
SOURCE: kenmore washer shakes violently during spin cycle
I have a Kenmore 22990 top loading washer. it shakes violently and walks across the floor during the spin cycle. it started doing it about two weeks ago. moving clothes around inside the tub does not help much.
Posted on Dec 01, 2007
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
The spin cycle is faulty
question to you is ? it draining all the way if not it cant spin.if not you need to check out your pump it may be blocked or failed
Jan 01, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Whirlpool CAM2752KQ Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
