Question about LG PM-225 Cellular Phone
Sim Card- Where is it located?
  1. Where is the sim card located - just got this phone and don't know where to put my sim card in.
  • 81 Answers
It does not have one. At least mine doesn't. So b e sure to back up your address book before you lose it or you upgrade!
Posted on Oct 05, 2008
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
My mobile is asking for a PUK code and i don't know anyone with an idea sim how should i find the PUK code for it??
PUK code comes with your phone sim card when you bought it.Try locating where the whole box or package of your phone. Some sims comes with a manual and usually the puk code are written in there..Others comes like a regular size card and you have to detach the sim from there..in this card thee should be two Puk code that is written..
Hope that this info has help you in anyway..have a nice day..
Feb 20, 2012 | Nokia 2626 Mobile Phone
How do you remove your sim card from the 6700 slide to replace with new?
I don't have this particular phone, but generally the sim card in under the battery. Before you start, make sure you have all your contacts and stuff stored on the phone, not the sim, or it all goes bye-bye when you change the sim. Snap off the back of the phone. Don't pry the battery out. Usually you have to look for 2 tiny little "latches" that hold it in. Sometimes there is a lever that you push to release the battery. Then you can see the sim card. Sometimes you release a little metal clip that holds it down. On other phones, you just slide the card out from under the metal holder. Pay attention to which way the card is turned, and don't put the new one in upside down. Then reassemble the phone.
Feb 01, 2012 | Nokia 6700 Slide Cell Phone
I dont know my puk number andmy pin is bloked resulting i me not using any of my mobie services help please.
Hi, In this please do contact your service provider and inform them that the PIN is blocked and the phone is asking for a PUK code for your SIM card and they would provide you with the information once you help them with the SIM card number located on the SIM card itself.
Thank you for your time and best wishes for your effort.
Nov 28, 2010 | LG Xenon GR500 Cell Phone
I dont know the puk code
  • Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  • Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  • Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  • See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  • Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
  • SIM cards come in different carrying capacities that may not work with all phones. Be sure to check with your provider to find out what size card your phone uses if you plan to purchase a SIM card from a source other than your cellular carrier.
  • Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself
Sep 25, 2009 | LG Vu CU920 Cellular Phone
Need PUK code, T-Mobile SIM is deactivated (cancel line)
  1. Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  2. Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  3. Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  4. See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  5. Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
Sep 24, 2009 | Nokia 8800 Cellular Phone
I need to know where to put the sim on my n73
at the back on the cellphone,, remove the battery and u see the sim card socket on it, the 6 pins that is the sim card socket that the exact location for the sim card
Apr 25, 2009 | Nokia Cell Phones
Insert sim
Hi have a repair shop, and you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
Dec 05, 2008 | Nokia 2626 Mobile Phone
LG PM-225 Cellular Phone Logo
285 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
