Question about Samsung Digimax S500 Digital Camera
Camera will not come on
I've check and replaced batteries, try to turn camera on, green light flashes and camera beeps 3 times, will not stay on and lens stays in.
  • 6 more comments
  • BRIGHTWAY Jun 18, 2008
    I've taken the card out, put batteries in and trying to turn camera on-NO LUCK
    tried taking batteries out, held down on bottom, put batteries in and let camera turn on-NO LUCk
    There's nothing in the manual to troubleshoot this problem.
    I've cleaned the inside where the batteries go and put batteries back in - NO LUCk
    what is the ccd and how do you clean it?
    I got it as a gift Dec 2007, but have hardly used it.
    ok we got somewhere, I turned it on and pushed aroung len (could hear motor), got it to come out and camera stayed on and works, however when I turn it off len does not go back in. Camera will take pictures. Guess it's time to buy new camera or us as is.
  • BRIGHTWAY Jun 19, 2008
    n/a
  • 2,071 Answers
Checked the battery by using a multitester,if there is a DCvoltage and clean the terminal of the battery .Terminal inside the camera so some residue of battery will taken out. If you are sure that voltage the right voltage is there and still not power on.The problem is in the system inside the camera need to flash the unit. Flashing is the solution of dead set unit ,to power it again. As I diagnose your problem your unit is need to flash.Service center for camera of your brand have this flashing device so bring it them.
Posted on Jun 18, 2008
    Guru:
  • 1,342 Answers
This seems to be a very common problem with this camera.
Read some of the comments on this site.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
I know it sounds dumb, but just to be sure, I would try a third set of new batteries. Make sure they are from a completely separate set of batteries. Go to a different store, and buy a different brand. If then it doesn't turn on, I would be convinced that its the camera. sometimes batteries are bad when you buy them because they sit in the stores and warehouses so long
so if you try three pairs and you are sure they they are all good (seems likely), then you camera seems to have a problem. Did this just start, or did it seem likely batteries just slowly didn't last as long? Was the camera dropped or shocked? Any rhyme or reason to this?
I'm guessing here, but these kinds of issues are often indicative that something in the camera's power management system is failing. This is often a replacement situation. I would certainly have it looked at by a repair shop, as it's unlikely that there's much you can do to solve the problem with "home remedies."
  • Samsung Master
  • 1,879 Answers
Power issue - change batteries - need power to push the lens out
    Genius:
  • 1,036 Answers
If you've removed batteries and memory card at the same time, then replaced with good batteries, and a card, and still get no joy, Then it will need dismantling to find the cause.
Ask at least 2 repair shops for a detailed quote before handing it over for repair.
Often it is cheaper to replace the unit.
Did is suffer impact or water before giving up?
It may just be grit in the lens, or force applied to the lense mechanism causing a jam. Try pressing on the lens area when turning on. Do you hear any motors starting or straining?
  • Richard Perkins
    Richard Perkins Jun 18, 2008
    Definately lense motor drive is damaged then. Probably cheaper for a new unit, but enquire at the fix-it shops for a price based on this.
  • 4,472 Answers
How long ago did you purchase the unit?
Thanks,
Lee
  • 3 more comments
  • Lee A.
    Lee A. Jun 18, 2008
    It is still under manufacturer warranty you will want to contact samsung. If you need their contact information let me know. You will only have to pay for shipping. Even though that is not fun it is still better then a whole new camera.
    If you need anything else let me know.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    Im sorry but when I am still ascertaining information it is not customary to rate a thanks for trying. Please wait til I have assisted you fully and if you still have problems let me know.
    Thanks and I hope you will accept and find this helpful.
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    Like I said it should still be under manufacturer warranty I would contact them first as It may only cost you shipping. Though it might be in the best interest to upgrade though. If you found this helpful please accept my solution and rate it accordingly as I try very hard to provide you with the best solution for your money.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Did you have something else you needed help with? I would hope you should have found something helpful in all this. If not please let me know why as I and I'm sure most everyone else try very hard to provide the best solution.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Let me know what you ended up deciding and if you get a moment can accept and rate accordingly it would be greatly appreciated.
    Thanks again,
    Lee
    Master:
  • 638 Answers
Problem with the ccd .try to clean it first. if that does not help u will hve to replace it with new part
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
  • 1 more comment
  • hemant somaiya
    hemant somaiya Jun 18, 2008
    any more assistance or updates
  • hemant somaiya
    send comments if its still not solved
  • hemant somaiya
    if not solved still go for the new camera.be wise
  • 87 Answers
You need to take all of the batteries out and take a paper towel or something, and wedge it into the battery holder and clean it out.... most likely it has dirty contacts. if this doesn't work let me know....
please rate this solution
    Genius:
  • 1,665 Answers
    Genius:
  • 1,447 Answers
Hi -
Try resetting the camera, turn it off and remove the batteries, press and hold down the power button then reinstall batteries and let go of the button when camera turns on by itself.
keep me posted, thanks!
    Genius:
  • 3,422 Answers
Remove the SD card and then insert the battery and see if it turns on.
  • Priya darshan Jun 18, 2008
    The other possible solutions are:
    You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
    Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
    If you still face the problem then the only solution will be to get it serviced as it can be a mechanical problem.
    The battery cover or CF card (SD card) slot cover is not securely closed
    Most
    cameras have a lock mechanism on the battery cover. The camera will not
    turn on if the battery cover is not locked or securely closed, or if
    the CF card (SD card) slot cover is not securely closed. Make sure
    these covers are securely closed.
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Camera wont turn on
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Kodak EasyShare C310 Digital Camera
Ps3 problem
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Samsung s360
that's because the battery is dead.
Jun 11, 2008 | Samsung Digimax S630 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Samsung Digimax S500 Digital Camera Logo
107 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
