Question about Jandy Laars Lt 400,000 Btu Heater
High Limit switch corrodes over time. Then it causes a High limit fault. Is there a cheaper place to get the high limit and low limit switches? I see them for $30 to $40 on the internet.
    Top Expert:
  • Jandy Master
  • 4,290 Answers
Bad header replace then replace high limits
Posted on May 25, 2016
  • 22 Answers
SOURCE: High Limit Swtiich message
The high limit switch is one part of a safety loop circuit that must work before a heater can fire. It's purpose is to ensure tha tthe heater will shut off in the event of a thermostat failure or if the internal core gets too hot due to a lack of water flow. If the switch is failing, it needs replaced. There are 2 so you can replace both or make an attempt to determine which one is bad. It is best to replace the pair.
Posted on Dec 21, 2008
PartsCenter
  • 125 Answers
SOURCE: high limit
that means you need to replace the high limit assembly
Posted on Mar 04, 2009
  • 128 Answers
SOURCE: Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Posted on Aug 23, 2009
  • 246 Answers
SOURCE: My Jandy LT 400k heater shuts off when the fan
my guess is you are a pool guy so im not going to awser this one
Posted on Oct 15, 2009
  • 64 Answers
SOURCE: My High Limit light comes on, along with service light.
Check your high limit switches. These can be found in the header. There will be two, and they are right next to eachother. You may pull them out and they may look like they are corroded or have gritty stuff on them. If that is the case, they will need to be replaced. However, this is usually an indication that the stud sensors in the header are corroded and the new sensors switches will again go bad. Unfortunately, the stud sensors are brass little posts, that were poorly made on some jandy heaters. They are available on a part, but near impossible to replace. So, it means you will likely need to replace the entire header or keep on replacing the high limit switches. HTH
Posted on May 30, 2010
I need to know where the high and low limit switches are located on a Winrich Dynasty pellet stove
The Low Limit Switch, goes in the combustion fan housing. The High Limit Switch, goes in behind the Room Blower.
Here's a repair site for you to check out, in more depth. Hope this helps! http://www.butkus.org/whitfield_operate/whitfield-pellet-stove-low-limit.htm
Nov 21, 2014 | Pool & Spa
My temperature says HI. but my temp is not warm
The error code is HL, not hi
This is telling you the high limit switch is tripping(safety feature)
Lack of flow, corroded heat exchanger, bad high limit switch, bad thermal regulator.....
Take these steps to try and get it narrowed down.
With heater off
Locate the high limit switch, unplug the two wires connected to it, put a jumper wire in between those two wires. Turn on the heater, if it fires you need to wait till it heats all the way up. If if heats up with no fault in the cycle then most likely it's a bad high limit switch, if it continues to trip then thermal regulator, it may need both parts.
If it doesn't fire at all then you will probably need a professional
Aug 17, 2014 | Pentair Minimax NT Heater
Dryer not heating model #LEA30A amana commercial quality
You need to unplug it and locate the high and low limit switches. These sense the heated airflow temperature. If it gets too hot, the high limit switch kicks off until it cools back down. The low limit switch is used most if the time to cycle the heating element on and off during a normal cycle. I suspect the low limit sensor switch is "open" (has gone bad) and needs replacing. When completely cool, both switches are supposed to be in the On or closed circuit position. You can test them with a ohm meter, looking for low resistance similar to when the two ohm meter test leads are touched together. Again, make SURE the power is off at the breaker or the dryer is unplugged.
Feb 27, 2014 | Amana Dryers
Fan works, but not AC cooling
start with checking a/c pressures is compressor cycling? does it have electric cooling fan? it should come on with a/c. usually there is a low limit/high limit switch. if pressure is low, say below 22psi @ low side port, switch will cut compressor. A quick electric "jump" of low limit switch will confirm clutch,compressor operation,but if pressure is low you may want to add freon. know your a/c system r-12 or r-134a,iv'e found converting to r-134a cheaper than purchasing r-12. r-134a takes a special pag oil and should not be used/mixed with ester oils. i could say more on subject but that's a start,of course always wear safety glasses and approach high side port with caution,which most newer cars don't have. thanks
Jun 27, 2012 | Heating & Cooling
Compressor cut out after 5 minute aircond working
Sound like the unit is going off on the high limit switch or low limit switch. If its going off on high limit your condenser coil is probably very dirty and needs to be cleaned. If it is going out on low limit its most likely low on freon and has major issues.
May 17, 2011 | Heating & Cooling
Furnace flashing open high limit
Hello, A limit switch will open when the furnace overheats due to low airflow, . check air filter, clean blower wheel, and check to make sure the blower wheel is running at proper speed and not dragging sometimes cause by a weak capacitor. Anything that restricts airflow will cause a limit switch to open.
Mar 07, 2011 | Goodman Heating & Cooling
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
High limit switch open on armstrong furnace
If you know where the high limit switch is you can always cut the two wires and wire them together causing the limit to close. But what you have to watch out for is why the high limit is not closing. That means in your return air either you have a dirty return air duct, dirty filter, or you don't have all your registors open to allow the heat to escape the heat exchanger. Just watch over riding the system. The high limit switch should either be on or behind the blower, in the middle of the system right under the heat exchanger. any other questions about hvac just ask.
David
Mar 23, 2008 | Heating & Cooling
Jandy Laars Lt 400,000 Btu Heater Logo
104 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
