I have an Acer Aspire 7736Z and i have had it for a year and it just shut off and will not turn back on.
Buy a new one ....
Posted on Jan 17, 2011
3 Suggested Answers
SOURCE: how to change the programmable button on Acer aspire 7736Z
Go to your Start Menu --> Programs --> Task Manager. It is the Task Manager that actually handles the action of this button.
Posted on Apr 02, 2010
SOURCE: how to change prorammable button on Acer Aspire 7736Z-4448
-Go to Windows Start
-Type in "Launch Manager"
-Choose whatever program you want to customize button to.
-If your program isn't listed there select "Add"
-You can add whatever program from your computer of type in a web address from there.
P.S. Acer doesn't list this anywhere, and they want to charge you for the info if you call them (so wrong of them).
Posted on Apr 16, 2010
Testimonial: "you fixed my problem! thank you so very much!"
After new hard drive how can i find my webcam
install webcam driver then only you can find your webcam
Mar 17, 2015 | Acer Genuine Ac Adapter Aspire 7736-6080...
I have an acer aspire 7736Z-4088, and it keeps shutting down, usually while I'm typing. Why?
Hi
this may sound strange but are you wearing a magnectic braclet ???
this is said to cause some problems of shutting down
also please check your power options in control panel
and make sure the hard drive is not set to cut off after only 20mins
many thanks
Sep 03, 2011 | Computers & Internet
I bought my acer aspire 7736z-4412 a little over yer ago. I don't do much on it other than check out facebook. It recently decided to shut down while I was online and now it won't start at all. I...
there are a few things that could cause this but here are the first two to look into before the last and worse case
your power adapter may have died. you need to have it checked. if it is ok then you porbably damaged the jack. if the jack is ok well then your motherboard has an issue. either the board is damaged or another problem exists.
Jun 29, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
Manuels for Acer Aspire 7736Z-4448 Model No.
Hi
follow this link and hopefully you will find what you are looking for type in what you looking for
http://support.acer.com/
Nov 15, 2010 | Acer Computers & Internet
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
How do I enable the bluetooth settings on a acer aspire 7736z?
Hi there,According to the Acer Manual for your Laptop,The Fn+F3 keys Enable/Disable bluetooth.You can find out more about your laptops capabilities here...
http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/QS_ACER_7736_7736Z_1_0_EN.pdf
Hope this helps,Good-Luck.
Aug 27, 2010 | Acer Aspire 4720 Notebook
I have an Aspire 7736Z-4809 and it seems that the battery isn't working. If I unplug the power strip the computer shuts off. Is this the battery or the settings or the plug? Any thoughts?
Unplug the laptop then remove the battery. Reseat the battery, plug the laptop back in. Then restart your laptop. Give it 5-10min to allow for a small charge and then remove your charger again. If the laptop shuts off immediately it is quite likely that your battery has failed. This is quite common for batteries. If you're under warranty please contact the manufacturer. Else you will likely find a cheaper battery solution on ebay. -Ravi Shanghavi
Aug 19, 2010 | Acer Aspire 5335-2257 Notebook
Acer Aspire 7736z - 4088 I can no longer get the
It may be wiring problems in the articulation area of the camera. This was my problem and others had same problem. Try moving the camera to a different position a little at a time and then try connecting again. I tried downloading drivers, etc. not the problems with mine.
Jul 12, 2010 | Computers & Internet
How to change prorammable button on Acer Aspire 7736Z-4448
Apr 01, 2010 | Acer Computers & Internet
How to change the programmable button on Acer aspire 7736Z
Mar 29, 2010 | Acer Computers & Internet
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
