Question about Casio Exilim EX-S880 Digital Camera
When the camera is turned on, a card error message appears. I am trying to retrieve the photos, however, in windows, it says that the memory card needs formatting. I know that if I format the card again, I will lose all my pictures. Is there a solution to this problem?
  • Dixie-Ann Herbert Nov 14, 2010
    The card was formatted already and was actually corrupt. I took your advice and was able to retrieve my pictures. You were very clear and helpful. Thank you.
  • 4,472 Answers
If you haven't formatted the card at all yet and the memory card is just corrupt there is a lot of software out there that will try and retrieve whatever it can. Most of them have a free trial that will at least show you what they can get off the card first then you will know if it's worth it to buy it. Here is one example:
http://www.cardrecovery.com/?rid=google&kid=cr0102
If you need further assistance let me know.
Thank you,
Lee
Posted on Nov 14, 2010
  • Lee A.
    Lee A. Nov 14, 2010
    Very glad to hear that.
    Thank you and have a great day.
Memory card error on fujifilm finepix series s4800
Eject the bad memory card and try another one. It is possible that the card in the camera right now has corrupted. You can try some of the online recovery tools to try and rescuse what is on the card if you have not already transfered the pictures off the camera.
Dec 10, 2014 | FUJIFILM Cameras
Memory Error
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 30, 2012 | Pentax X70 Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
I am trying to retrieve photos to print online from my Canon SD630 Digital Elph but I get a message "communication error" on the bottom of the camera screen. I am able to retrieve and print photos from...
First, I'd give the connectors on the card a buff with a soft dry cloth.
When finished, check if the card has a write enable notch on the left hand side, make sure the notch is in the right position.
If the notch is broken, cover the gap with a little sticky tape, just like you used to with tape cassettes.
if that doesn't work
You could buy/borrow a universal card reader, and connect that to your PC. Works just like another hard drive.
If that doesn't work, try you card in another compatible camera, if it still fails, your card has a problem. The only thing left to try is re-formatting in the camera and that will clear all data from the card.
Jul 10, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Apr 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Memory card error
did you try pluging the card into the pc using a card reader
May 01, 2008 | Archos AV400 Digital Media Player
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Memory card problem
hi
I was happily using Cannon IXUS 750on one of my long vacations when the memory card almost got full. perhaps I clicked once or twice to take a picture when the card was full. ever since the camera displays Memory Card Error.
These are almost all the photos I took on my camera since a long time now. Could anybody pleeeese help me in retrieving my photos and recordings?
thanks v much
Nahar
Oct 30, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Casio Exilim EX-S880 Digital Camera Logo
61 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
