Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Need to know about the installation of the snow blade
Snow blade assembly-diagram
The H should match up to front and center of tractor.
Dec 18, 2014 | Garden
I put my snow blade on successfully, but the tractor does not start now! What to do?
Did it start before you installed snow blade? Did you remove mower deck? If you removed mower deck you probably had to unplug blade safety switch. This is a plug in deal, look underneath and see if it is hanging, there is probably a place on the snow attachment to plug into,or you can jump around it by plugging a wire into each hole. (please note I am assuming it ran good before you installed the snow attachment).Hope this helps.
Dec 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do you install blade on 12hp LT model no.917.254241
what model blade do u have? can you email a copy of the installation intructions?
Nov 24, 2009 | Craftsman 16" High Garden Tractor Snow and...
I bought this dozer blade uses and cant figure out how to attach it to my tractor. Is there a mounting bracket that bolts onto the tractor? Are there any pictures of this or an installation manual with a...
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Nov 16, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Dec 14, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
