Question about Maytag Dishwashers
My mother has cancer so needs me to research her problem with her dishwasher. My mother's sink drain water is emptying into the dishwasher. It has to be manually removed since she does not cook much and therefore no longer uses the dishwasher as much as she used to. Is there anything I can do without calling a repair man or plumber? And if I must call a repair man, which should I call, a Maytag repair man or a plumber?
  • 5,911 Answers
Problems associated with water from the kitchen sink back filling into the dishwasher are caused by the drain line on the dishwasher not having a high end loop. In simple terms, the dishwasher line is too low and is providing a path for the water to flow in the wrong direction. Reposition the drain line so that it loops just above the sink drain. Then, anchor it to the wall so that it does not move. This will provide and air gap and creates just enough resistance to keep the sink water from entering the dishwasher. I have included a link to a webpage that illustrates what I am referring to:
http://homeimprovementteam.com/standing-water-in-dishwasher
If you have any further questions, please post back and let me know. I hope this helps you.
NOTE: If you are experiencing problems with the sink draining as well, then you may have a plumbing releated issue.
Posted on Nov 14, 2010
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
The water is not emptying completely out of my dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 09, 2011 | Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
Dishwasher turned on accidently and full of water
Close the dishwasher door and run the drain cycle of the dishwasher only....that should empty the appliance. Note that a little bit of water remaining is normal, but if there is a substantial amount of water left, you will need to check the pump inlet screen and the drain hose or sink for any additional clogging.
Apr 02, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwsher wont drain. never happened before. do not use dishwasher very often.
I would first check where the drain hose from the dishwasher connects to the drain stub under the sink. Remove the hose from under the sink and place it into a bucket. Close the dishwasher door and cancel the cycle to put the dishwasher in a drain cycle. Listen for the drain pump to activate. If water comes out of the hose check the stub where the hose connects under the sink with a screw driver to make sure the spout is clear of debris. If no water comes out of the hose, empty the dishwasher by hand using a plastic cup and when empty remove the hose at the pump under the dishwasher and check to see if there is any debris at this point. Make sure hose is clear from the dishwasher pump to the drain stub under the sink. You will need to place a towel or two on the floor as water left in the bottom of the dishwasher will come out when you remove the hoses. If still no water comes out you may have to disassemble the bump assembly. Not knowing what make and model you have I can't help you past this point.
I hope this is of some help.
Jan 25, 2010 | Dishwashers
Had blocked drain so water from sink backed up into d.washer. Drain clear but d.washer keeps emptying and won't fill
Make sure drain hose from dishwasher is higher than water inlet if not it will do just like a washing machine if the drain hose is lower than water level it will empty while filling.
Jan 19, 2010 | Dishwashers
WHEN I RUN MY SINK IT DRAINS INTO MY DISHWASHER BOTTOM. I HAVE SNAKED THE HOLE AND IT STILL FILLS THE BOTTOM THEN I RUN IT EMPTY THEN FILL AND RUN AGAIN. HELP
The dishwasher drain line that connects to the garbage disposal or pipe under the sink should be looped above the height of disposal or pipe to prevent
sink water from backflowing into dishwasher.
Most dishwashers have some form of internal backflow preventer inside the water sump assy..
Yours may be degraded or stuck open.
Jan 16, 2010 | Dishwashers
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
61 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
