Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
I have a starite propane heater i turn it on it calls for heat it will start heating then a couple minutes later the filtration lines and heater give a loud banging noise and service heater light comes on no code? please help
  • 310 Answers
This is either one of two thing.
Either you pump is clogged, or failing and not providing adequate flow, or the heat exchanger has a hole in it. I would hope that it is just a flow issue as the exchangers are very expensive.
Check the pump first, and also make sure there is no leaking water from the heater
Posted on Nov 15, 2010
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
SR333LP turns on but does not heat
hot surface igniter may not be getting hot enough to ignite the gas
Jun 05, 2013 | Sta Rite Starite 333 Btu Propane Gas...
I have an aqualink rs and my spa heater isn't working. I checked the propane and it is full. The heater was working 2 days ago. Now I turn spa and spa heat on the filter pump comes on and the red light...
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Mar 12, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool heater on but not heating
Here is a manual that will help you troubleshoot.
Run the diagnostic tests pages 15 - 16 and then see pages 17 and 18 for troubleshooting flow chart.
http://www.starite.com/pdf/S5600PS(2-8-01).pdf
Kelly
Feb 22, 2010 | Sta Rite Sr333lp - Max E Therm - Pool &...
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
Not able to turn on and see anything on display of starite Spa / pool water heater. Any tips on where to start troubleshooting.
I just had my service heater light turn on with no heating and not able to increase or decrease any temp numbers. Any suggestions
Aug 30, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Intertherm propane furnace makes popping sound when running
It sounds like you have a possible hole in the heat exchanger. Turn the heat off and turn the fan on. If you feel any air coming back out of the heat exchanger, you have a hole. A yellow flame is not a good sign. I would even consider having a service professional come out and take a look.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
No heat
First figure out if your unit is a heat pump, (where the unit outside both heats and cools your home) or it may be a propane or nat gas furnace, it could also be a hydronic heater (the water heater heats the home) let me know what you find out.
Oct 30, 2007 | Weather King 10AJA2501AH Air Conditioner
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
262 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
