Question about Sony Computers & Internet
I get an error message that my battery may not be compatible or it needs to be removed and reinserted. It's the same battery that came with machine and it showes a full charge, but the error message won't go away.
Try updating or rollback ur battery drivers from the manage option in my computer.
if problem still persists then take the battery out and dont connect it with charger code. then press laptop power button so tht extra energy left in laptop can be removed. press button for some seconds and then try again with battery and see if the problem is resolved.
Posted on Nov 14, 2010
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
I have a sony dsc-t90 camera when i turn on the power there is error massage {for compatible battery use only}i change a new battery but the problem is still there so is there any body can help me what is...
The compatible batteries for this Camera are NP-FD1, NPBDL.
Please make sure that you're using compatible battery pack.
Remove and reinsert the battery pack, while the Camera is turned off.
Reset the Camera by removing the battery while the Camera is ON and reinsert the battery after a minute and turn on the Camera.
If the issue is not resolved the Camera needs to be serviced, as it will be the issue with the hardware part of the Camera.
Aug 22, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
On my blackberry screen it says app error 523 reset
On the BlackBerry smartphone, the 523 app. error Reset error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry Device Software must be re-installed.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
1. Remove the battery and run loader.exe from
C:\program files\Common Files\Research In Motion\AppLoader.
2. Remember to reinsert the battery after the loading operations begin.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry Pearl 8100
ERROR MESSAGE C 31:23
The error code is part of a self diagnosis feature of your cam. This particular code refers to something being wrong which you can fix yourself. The steps you should take, involve removing tape, and reinserting. removing power adapter plug and reinserting, remove battery pack and reinsert...
power down before each step, and power up again to check working status. The result of these checks should allow you to narrow down the problem.
You may have to look at trying a new battery, or replacing the cassette, or replacing power cord, or you just had not properly hooked something up, or the cassette wasn't properly seated.
These codes and their meaning can be found in your user guide, or manual. Good Luck!
Nov 11, 2008 | Sony Handycam CCD-TRV108 Camcorder
Call failed error
Perform the following steps to try and resolve the issue:
  1. Remove the battery cover.
  2. Remove the battery (while the device is still powered on).
  3. Remove the Subscriber Identity Module (SIM) card.
  4. Reinsert the SIM card and the battery to reset the BlackBerry smartphone.
Jun 24, 2008 | RIM BlackBerry Curve 8310 Smartphone
Help please
I'm assuming you have a lens error which is giving you the restart message.
It is kind of misleading, but to restart the camera means to power cycle the camera or remove and reinsert the battery.
If you do have a lens error, if restarting the camera doesn't work, you'll need to get the lens fixed if to remove the error.
Dec 17, 2007 | Canon PowerShot SD600 Digital Camera
ERROR MESSAGE
please check and clean the unit where ink cartridges are located
Sep 21, 2007 | HP 920 Plain Paper Fax
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
