Tell me where to start - Computers & Internet
I need help getting my Grandaughters tablet started . some one said we need ?a hard start" ?? Or something on that order. No phone here right now so I am on my Apple tablet .Can someone help us
can you please try and tell me what the problem you have with it?
why have you been told it needs a hard start mind you i have never heard of a hard start before.so to help you please try and tell me what is wrong with it.
Dec 09, 2016 | Apple Tablets & eReaders
Tip
Remote start won't start? Just honks or blinks lights at you?
If you have a remote start installed on your vehicle and it will not start, instead it would rather honk at you or flash the lights at you, don't get mad at it. Instead be patient, count how many times it honks or flashes at you because these actually mean something . It is communicating with you, trying to tell you its problems. In every user manual for every remote start I have ever installed (well over 1000) there is a section that tells you what is going on when this is happening. It will tell you for example on a Ford Bronze remote start that 6 honks means it is in valet mode.Look in the manual and it will tell you how to put it in valet mode and also how to take it out of valet mode.
Trust me, I have seen way too many people make an unnecessary trip to our dealership all because they never even pulled out the user manual that I put in their glove box after installing their remote start.
on Dec 02, 2010 | Ford F Cars & Trucks
I have a 99 trail blazer four wheeler and will start but when I turn it off it will start again..can you tell me why it will not start again
Read your question
You Say: you turn it off it WILL start again
You Say: tell me why it WILL NOT start again
NO--- can not tell you anything
Vehicle Problems are FOUND by doing the required testing
Problems are ONLY step one
Then you have to come up with a repair solution
That is what this(free) (at home site) is famous for ---solutions
Well --without a vehicle to test, your best solution is a repair shop
or learn your vehicle systems & how to test them
For that, you need a large investment in factory manuals
Jul 19, 2014 | Cars & Trucks
Why wont start when cold
Sounds like a bad starter
May 17, 2014 | 1998 Ford Ranger
I had a guy to tell me it would be the fuses so if there can tell me the problem is what wrong with my car the car wont start I go into the store and come back it wont start everything work but my dash...
Here is an example of a stupid question
A guy --- tells you with no testing-- you have a fuse problem,really!
Can you tell me the problem--NO ONE CAN
It won't start --so someone on the internet should be able
to guess at it,again with NO TESTING what so ever
Tell them what's wrong with the radio,again really,The Car Won't
Start, who cares about the radio,you can't use the car
May 03, 2014 | 2000 Chevrolet Malibu
Difficult to start when cold
sounds like ur battery is draining. cold wheather is a definite battery tell tell
Nov 09, 2012 | Bosch 1992 BMW 525i Cabin Air Filter
When i start up my laptop it tells me that i have to restart and i keep restarting it but it keeps showing me the same screen telling me to restart
mine just started doing the same thing. I am assuming that I will need to reload the system software. Did you find the solution to your problem?
May 17, 2010 | Computers & Internet
Have power and light. can't hear compresser run
could be a bad start relay or start cap. could be a bad compressor. if you have an electric meter you can test the ohms of the compressor and that can tell you if the windings are good, however it cannot tell you if the piston is locked. if you have a locked rotor condition and bad starting components you will not be able to tell until you replace the bad starting components and test run. if it hums and draws lots of amps its locked rotor. most compressors will tell you RLA and LRA amperage, LRA is locked rotor amps, RLA running load amps
Oct 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Can start the car in the morning, can start the car at night, when I get off of work, but if I stop at a store,(maybe 15-20 minitues after) and I turn off the engine, it won't start. I have full power. But...
Check the Coolant Temperature Sensor - might be defective (lies to the computer ECM). You see, the coolant temperature sensor tells the ECM (computer) what the engine temperature is... if it's defective (telling the computer that the temp is -40 deg, then the computer will raise the fuel mixture for that temp. If, for example, the sensor is telling the computer that the temp is 200 deg, then the computer will 'LEAN' the fuel mixture.. get my meaning?
Sep 10, 2009 | 1995 Chevrolet Corsica
93 accrod hard to start.
thank for the quistion ,but you have to tell me the motor type , or at least , tell me if it is carbrator or injection , thank you for using fixya
Jun 25, 2008 | 2003 Honda Accord
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
