Question about Fontaine Home
Hello I have just installed a Fontaine shower set NF-BELTS-CP and I cannot get the water hot enough. I am sure that there may be some kind of adjustment but I am not sure what it is and before I start experimenting I wanted to ask for help! I get OK pressure but the water temp on max is just too cold yet I konw that there is hot water coming to the valve as the sink can get hot water... What can I do to adjust the water temp to get a hot shower??? Please help!
  • 3 more comments
  • slewin709 Nov 15, 2010
    Hi Vetteman3002
    Unfortunately that's the rub, the unit (and I have 2 of them) did not have any instructions regarding specifically how to adjust the tempeature with this unit? I agree that in most cases the units come with instructions but unfortunately this set(s) did not... Only how to install it but nothing on how to adjust it.... This is where I can really use the help
    Any thouhts?
    If anyone has any idea on how to adjust the temperature on the Fountain shower unit that would be really helpful. Unfortunately the instructions I have do not go into that detail and I could not find the answer
  • slewin709 Nov 17, 2010
    Unfortunately I do not think that this is not the case here. I have a Kohler system in the Master shower that gets really hot so I am not sure that it is the water heater. Also the water at the sink is much hotter then the water from the bath so something is out of adjustment.... What I am thinking is that the adjustment at the factory may have been off. That is what I am looking to see how best to adjust? Any recommendations?
  • slewin709 Nov 21, 2010
    that did not work, we tried that before I sent in the request for help and then again..
    I have the water heater up and the other shower whith a Kohler set up works fine. So we checked it again. Unfortunately there is something wrong with the set up in the head and that where I need the help. This last answer did not help...
    awesome this is exactly what I was hoping for
    We will give it a try
    Guru:
  • 642 Answers
This unit is indeed adjustable.
You'll need an adjustable wrench and philips and small flat screwdriver.
However the temperature water coming out the faucet should be the same as out the showerhead as these two are on the same pipe after the cartridge.
To adjust:
Pry off the cap on the handle. Undo the screw in the handle and remove the handle. Remove the collar below the handle with the tool provided and remove the collar.
Unscrew the backing plate and remove. Remove the plaster guard.
Remove the base nut and its retainer nut to expose the cam.
This cam can be used to adjust hot water temperature. Note its position, remove it and move clockwise of its present position to increase hot water temperature.
If youre not at the correct temp yet :
On both the hot and cold inlet pipes are stop valves that can be adjusted by screwdriver to increase/decrease water flow. Open both fully.(counter clockwise)
Posted on Nov 18, 2010
  • 643 Answers
Well if all you did is install the hardware then what you need to do is adjust your water heater to the desired temp. the hardware doesn't control water temp.
Posted on Nov 17, 2010
  • 2,299 Answers
These can be adjusted by removing the handle and accessing the re-stricter plate behind the handle. All faucets are different. Your instructions that came with the faucet should have the instructions on how to adjust.
Posted on Nov 15, 2010
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
We installed a Fontaine shower head and the water flow is very low for the hot water and it is not warm.
Your issue sounds like a control issue and not shower head. Look for shut off valves near the control valve. If all is okay, disassemble and clean the control valve.
Sep 21, 2010 | Home
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
I have a Brizo Shower and can't get the water hot enought
I am not sure but I think the shower will work with out the limiter on it .  try that
Apr 14, 2009 | Delta Plumbing
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
Need a shower valve replacement cartridge
I found the cartridge at globeunion [nooutgoing@email.com], 888-328-2383. They told me they are shipping the cartridge to me today at no cost ("lifetime warranty") and they immediately emailed a part diagram of the whole Fontaine NF-VCTST-BNV-TSRVH Single Handle Pressure Balanced Tub and Shower Trim and Valve with Rain Showerhead (from the Monaco Series).
Larry
Jan 29, 2009 | Fontaine NF-VCTST-BNV-TSRVH Brushed Nickel...
Replacement cartridge for the Fontaine a NF-VCTST-BNV-TSRVH
efaucets.com 1-800-891-0896 they are an authorized Fontaine Dealer.
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Home Logo
395 people viewed this question
Top Fontaine Home Experts
Donni Steen
Tom Chichester
Are you a Fontaine Home Expert? Answer questions, earn points and help others
