Question about Kenmore HE2 Plus Front Load Washer
Model 48102 lights flash and beep continuously,and washer wont do anything
  • 76 Answers
SOURCE: wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Posted on Jul 07, 2007
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
Have you had a storm or power surge lately. May need a new electronics panel installed. That is what happened to mine. Once it is fixed, you should get a surge suppressor that is made for major appliances
Posted on Apr 27, 2008
  • 4 Answers
SOURCE: Kenmore Front loader Washer Problems
Hi, I got this exact Kenmore washer from Black Friday.  They finally installed last week and the vibrations were way out of control!  I looked around the machine and inspected the installation manual after spending hours leveling the thing and finally figured out that most likely cause is the foam shipping part at the bottom of the machine.  I called Sears to come back out since I have a pedestal screwed on the bottom, trapping the foam.  They came out and didn't think it was the issue.  I asked them to take it out anyway, and sure enough it worked.  For the first time my machine is working just the way it should...I wonder how many washers were installed this way?
Tip: To confirm that this is the problem, if you push down on the drum from the inside of the washer, you should be able to make the foam squeak...there's your problem!
Posted on Feb 08, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
SOURCE: Kenmore 48102 Front-Loading Washer
I have had the same problem. I unplug the washer for a couple of hours and then run the rinse/spin cycle and it takes care of the problem. I've had my machine for 2 1/2 years and this problem started exactly after the first year ended. The first time it happened, I called for repair but before the repair guys came I tried this and so far it has worked. It happens about every few months.iIt's a pain but so far no repair guy bill, yet.
Posted on Jan 12, 2010
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Lights flash and beep nine times
Hello, there might be a faulty wire that is connected to the motherboard, or a wire that is detached from the motherboard. I would consult the company's customer service first and make sure that it is the motherboard first before, I spend a large sum of money replacing something that was never broken in the first place. Maybe it's just a faulty wire, or something small. Consult the customer care first, before doing anything drastic. Best Regards
Mar 21, 2014 | Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
Wont spin just continual beeping. is water pump block?
does light come on 5 from right to left? If so it is the electronic boardneeds changing. if the pump is blocked you should get three lights right to left 5, 3,and 2 on
Sep 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Lights # 2 and #7 flash and beep
If the lights are showing the correct code, the motor controller is faulty because the 'tranducer is out of range', When Motor Controller boards fail, it's often because of another component has failed first...Best you consider a tech...Good luck....Nomess
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Washer 48102 starts filling then stops
the pressure switch should be tested for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Beeping
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
Mar 21, 2009 | Whirlpool GHW9400 Duet Washer
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
160 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
