Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
I have a 3.5 capty front loading model #131801400 the light comon on the panel but will not set to start I tried every troubleshoot problem in the booklet I received and not any of them solve the problem
Frigidaire Gallery GLTF4920ES3 Front Load Washer keeps powering off and on during a cycle. The LED panel goes crazy when it's off, no error codes, just a horizontal then vertical line and random cycle...
To get a diagnostic code out of this take the screws off the lid. There should be a manual on this model. You have to hold start and cancel together with the machine off, but plugged in for 5 seconds on this model. If you had a long fill problem on this unit the machine clunks out and doesn't operate correctly. Refer to that tech sheet to see how to reset the error codes on the unit and try again. If your machine has 8888 display instead of just little led lights, the error codes are much easier to read and understand through the tech sheet. To put the unit into diagnostic mode, you have to set the dial all the way to the specified cycle setting and follow the instructions from there. It will throw only an error code if you hold Start and Cancel together.
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
The light is on "control lock". I cant get the
Make sure the front loading door is closed to latch well The limit switch of the door can be faulty as it is necessary to get the washer to start the cycle-- a protect mode.
So use a multilmeter to check the switch, line to the switch from the control panel
Nov 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
Door open signal
this is comon its the door micro switch they cost pennies to buy but pounds to fit,,,wip the top off and you should see the door switch by looking from the top its right by the door lock
Jul 04, 2010 | Whirlpool AWM6100 Front Load Washer
Aspire 5100 wont save when i shut down
It appears that the C dirve is using 98% of space. Let us try to delete some temporary files, to do so, click Start Menu> Run> type %temp% and hit enter. It will open the temporary folder, delete all the files listed in this folder. Now, again click Start> Run> type prefetch and hit enter, it will open the prefetch folder, delete all the files listed on it. It should take care of the issue.
May 20, 2010 | Acer Aspire 5100 Notebook
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
1999 Chevy Venture - DIC quit working
It is comon that the DIC will fail this way. They are not very expensive on the average. I hope this helps.
Thank You,
Roy
Aug 07, 2009 | 2000 Chevrolet Venture
Lock light doesn't go on, won't fill, metal rubbing sound
thins sounds like a bad control board and wax motor issue, comon for this machine prbably about $300 for you to repair ,closer to $500 for aservice co. however, you say oyou hear a metal on metal rubbing thisi a sign of a more serious problem of rear bearing NOt worth cost of repair.. one way to tell the rear bearing is to open the washer door and grab the inner basket, try to lift it up you should have no movement iff correct. ifyour able to lift teh inner tuban inch or so, independently of the machine, i would venture to say oyou need a rear bearing// i mean new machine!!!!
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Indesit
hi there first of all check your filter located at the front of the machine for blockages as this is a comon fault, failing that next time the dial clicks round count the amount of times the red light flashes before it does a pause then starts again, and let me know how many flashes it does as this corasponds to a fault code
murdozzz
Dec 09, 2007 | Zanussi WJD1667W Front Load Washer / Dryer
Washing Machines Logo
134 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
