Question about LG 42LC2D 42 in. LCD HDTV
I have a 32 inch Dynex flat panel TV that stays bright with no brightness adjustment. Colors are there, but are washed out. All video inputs are the same. Any ideas.?
  • 9 more comments
  • KARL LIGHTNER Nov 15, 2010
    Hi, sorry about that, the model number is DX-LCD32-09
  • KARL LIGHTNER Nov 16, 2010
    The model is DX-LCD32-09 I really hope I can fix this. I'm a retired Radar technician of 42 years, but I know very little about LCD TV's.
    Here is a picture of the TV menu screen. Very bright and washed out. Sound is good.
    Someone has one of these T Con boards on eBay for $55.00 . Is this a good price and is there a high probability that this is really the problem?
    I don't even see what looks like a Tcon board. There are two boards. One is a power supply and the other looks like the main board. The part numbers are ATTACHED IMAGES.
    Hi Taran, another guy said it was probably te Tcon board, but after removing the back, I only see the main board and the PS board,. Do some sets not use a separate Tcon board? I tried to attach pictures but when I click on pictures, nothing happens. Karl
    I hope the images I attached get through. I must be doing something wrong. I don't see a TCon board unless it's built into the main board.
    I found the Tcon board buried under a metal bracket. It has the same part number as the one on ebay, but min has only two edge connectors while the one on ebay has four edge connectors and it is wider.
    i found the Tcon board, but the one on ebay is a different board even though it has the same part number CPT 320WF01C
  • KARL LIGHTNER Nov 17, 2010
    THIS IS MY TCON BOARD. I hope I can find one.
  • KARL LIGHTNER Dec 03, 2010
    I bought a new TCON board and installed it. The picture is no longer negative, but exactly half of the screen has a yellow cast on the left side. Colors look good, but what ever is supposed to be white on the left half of the screen is yellow.
  • 4,889 Answers
Seems like a problem with the mainboard or the t-con. Can you please get me an image so that I can have a look?
Posted on Nov 15, 2010
  • 4 more comments
  • eagle338
    eagle338 Nov 16, 2010
    Don't worry this is an easy repair, but we have to confirm it. Can you please get me an image of the screen with the set turned on and/or tell if the sound is affected when the picture gets distorted?
  • eagle338
    That does look like a t-con board issue. It is the one located at the center of the set above the audio/video mainboard. You need to take the back cover off and get me the part number thats on it, so that I can find you a replacement. Its very easy to replace, there are just a couple of connectors, that need to be removed and the board needs to be unscrewed from the chassis.
  • eagle338
    Yes. That is a good proce. But I suggexst that you order by part number and not the mordel number of the set. Yes there is a high probability that it is a faulty T-Con.
  • eagle338
    This is an LCD tv right? Also I do not see any attached images?
  • eagle338
    eagle338 Nov 17, 2010
    Check the revision version of the board(ex rev 3.0 or 3.0 or something like that). That is the reason I have asked you not to purchase it right away. As you can see, it is very easy to get the wrong part.
  • eagle338
    I am on it.
  • 10,515 Answers
Kindly mention the model number?
Thanks!!
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Dynex dx-l321-10a no video
No video or no brightness? If no brightness on a LCD get the room very very dark and with a flashlight on the screen look to see if a faint (very faint) image of the picture can be seen or not.
Dec 17, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Dynex 32 lcd hdtv L32-10C color is flashing green and purple
Just go to the service center where you bought that tv ,cause its ,one year warranty period. just consult your tv to the costomer service personel.
Jun 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When we watch our insignia television anything red in color looks as if it is jumping or quivering...why is this?
This sounds like you are using a composite, S-Video, or RF cable input.
The quality of these inputs are not as capable as component or HDMI, so colors are not separated as well. Red is a color that saturates heavily and will cause bleed as well as dithering...especially intense colors (bright green, bright blue, bright yellow, bright red).
To reduce this visual annoyance you would need to soften the video output from the player (not easy to accomplish), or upgrade to a better cable connection.
Hope this helps!
Feb 14, 2010 | Insignia IS-LCDTV32 32 in. Television
I connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Jan 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Got a 32 inch dynex tv how do you get the direct tv to work on it
the tv or direct tv comes with the hook-up cables. try one of those and remember the TV input where you plugged in the direct tv box then on TV remote or front function button change the input. :)
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Just brought tv home and it is too bright. nothing i do changes it help me
try going into the menu of the tv and adjust brightness lower or in some cases flat screens have an option for picyure quality like , sports , movies , try putting it on movies and sometimes that will take away brightness
Apr 25, 2009 | Dynex DX-LCD32-09 LCD TV
Bright colors bleeding onto picture
if you tried adjusting all parameters in the menu and anything you do is not resolving it, go into any workshop to have them replacing the main board. It looks ugly this idea but now days this kind or repair is posible and the board is "affordable". find any workshop close to your area. The reason of this idea is because the main board controls all parameters in the tv and the other part who we can blame on is the screen itself so if the tv is repairable (economical to repair) the workshop sure it would tell you.
Apr 08, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
LG 42LC2D 42 in. LCD HDTV Logo
94 people viewed this question
Computer Repairing
Computer Repairing
