Question about Kitchen Ranges
MY BUDDY HAS A FRIGIDAIRE MODEL FGF337AUE STOVE THAT THE TOP PART WORKS BUT THE OVEN DOESNT GET HOT. HE SAYS THE GLOW IGN GLOWS BUT WONT HEAT UP
SOURCE: oven element in IAG stove
Sounds like the thermostat is faulty but odd that both ovens fail to the same degree. It would probably be worth having the thermostat tested. Our IAG IOM6SE2 had the beeper volume go to a quarter volume - perhaps a similar problem. It is under warranty but IAG are not too keen to fix it. They first said, if it is a setting then we will bill you, and then, if it was caused by a power outage then it is not covered. (How can you tell?) They also suggested we claim against our home insurance. I have tried to find a service manual on the web, but no luck.  If I had a circuit diagram I could be of more help.
Posted on Apr 08, 2009
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: Kenmore gas stove, broiler works but oven won't
Hello, I'll start by saying this may sound odd considering the info you provided, "ignitor glows...". It is actually the ignitor you'll need to replace. Being that I do service for sears I've replaced numerous ignitor's, both bake & broil, but bake being most common as it is typically used more frequently. I'll try to explain... The simpliest way to put it is this, the hot surface ignitors function like a large resistor. As the ignitor glows it reaches a value to allow the gas valve to open and lite the burner. If the ignitor is even slightly worn/off it won't ignite the burner, hence it need's to be replaced. Hope that help's explain what & why. If so please take a second to rate the solution I provided here at fixya. Good luck and thanks for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
jsrock516
  • 5911 Answers
SOURCE: My stove top and broiler work but my oven won't
It's a good possibility. The broiler and oven use separate igniters. So, if the broiler works, you don't have a gas problem. The surface igniters use an electrode via a spark module, so its a completely different ignition source.
No ignition in the oven is most commonly attributed to an oven igniter that is going bad. As these igniters age, they become weak and require replacement. The following link explains some theory behind how they work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacements parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary, so shop and compare.
NOTE: If the replacement igniter comes with a connector plug that does not match the one on your range, you will be instructed to cut the old connector plug off and splice the wires together using a set of ceramic wire lugs that are included in the replacement kit. DO NOT attempt to use standard wires lugs. They will melt due to the extreme heat in an oven. The ceramic lugs and the wires on the igniter are heat resistant.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Dec 24, 2009
Whirlpool oven wont light
The igniter has to heat the thermocouple to turn on the gas valve so if the igniter is glowing brightly either (or both) of those components could be at fault.
Mar 11, 2014 | Whirlpool Kitchen Ranges
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
My Gas stove Kenmore Model #362.75471690 The
you need new glow coil for over it may looklike its working glowing orange but it isnt getting hot enough so you neeed replace it
Feb 03, 2010 | Ovens
My gas stove model # 790.77471792 does not heat up past 100 deg. The broiler and the the top burners light. can someone tell me what the problem could be? i did notice that when I turned on the pre heat I...
The orange glow you see is coming from the oven igniter. The igniter needs to glow white hot in order to light. You need to replace the oven igniter. Hope this helps.
Nov 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
GAS STOVE - MODEL GLGF377 - FRIGIDAIRE - OVEN SMALL EXPLOSION
find the broken part and replace it. it really is that simple!!!!
now seriously, you need to explain what is wrong.
let us know what kind of problem you are having... ie. the oven glow bar glows but doesnt let gas in to heat.
if this is your problem then replace the glow-bar ignitor and that should fix it.
give us more info and we can help you out.
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Hello, I have a Frigidaire Range stove Model #FGF378WCCD. The oven ignitor heats but the oven doesn't light up and we smell no gas. What can it be?
if the ignitor may glow but if it isn't turning almost white it is not getting hot enough to open valve ,,,,, make sure it glows very bright and if not replace it / larry
Nov 29, 2008 | Frigidaire PLEF398AC Electric Kitchen...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
