Question about Kenmore Dryers
Kenmore Electric , Model 11062612101 dryer won't turn on - I have check all the electrical connections. Push start button and it won't start
  • 5,911 Answers
The most common cause of a dryer that will not turn on, is a blown thermal fuse, bad power cord, or a broken drum belt.
If the voltage at the wall receptacle is correct, check the voltage again at the terminal block where it connects to the dryer. Make sure you UNPLUG the dryer and remove the the small access cover where the power cord is installed. You should read 220-240VAC at the wall receptacle and terminal block. If BOTH readings are good, the problem is INTERNAL to the dryer. If bad at the receptacle, you need to double check the power source that feeds the wall receptacle. Some homes use two separate 120VAC breakers instead of one 220-240VAC breaker. Make sure the breaker(s) is not tripped. If the reading is normal at the wall receptacle, but bad at the terminal block, replace your power cord.
If the problem is internal, the thermal fuse will be mounted on the blower fan housing. It is a small plastic looking component (usually white in color) with two wires attached to it. Disconnect the wires before taking any resistance checks. If the fuse is good, it should read something close to zero ohms. If bad, you will read an infinite reading. These fuses DO NOT reset and must be replaced if bad.
The thermal fuse can be accessed by UNPLUGGING the unit and removing the REAR panel behind the dryer. With the panel removed, the thermal fuse will be located on the blower fan housing on the lower LEFT-HAND side.
NOTE: For an exploded view diagram of your dryer, refer to any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
The Thermal Fuse is listed as item 59 under the "Bulkhead Parts" section.
NOTE: If the thermal fuse is blown, it generally blows for a reason. This could be an indication that you have a clog in the ventilation system, causing the dryer to overheat. Do a thorough inspection of your dryer, BEFORE replacing any defective parts. Failure to do so, may result in repeated failures of the same parts.
If the dryer belt is broken on this model dryer, the dryer will still heat, but the drum will not turn. You would still be able to hear the motor running if this was the case. The dryer would still produce heat as well. If your dryer does not exhibit these symptoms, then your belt may still be good.
Another cause of a dryer that will not turn on, is a broken door switch. An easy method to test the switch is to open the door and press by hand. If the dryer drum light is working, you should be able to toggle the light on and off. If the switch is found to be defective, it must be replaced.
The door switch is listed as item 41 under the "Cabinet Parts" section.
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If the model number is correct, the part number you may need are as follows:
These solutions are not all inclusive, but are the more common failure items. The more expensive options are a defective timer or drive motor. If you have any questions about these repairs, or need instructions on how to access any of these components, please post back and let me know. I hope this helps you.
Posted on Nov 14, 2010
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Dryer will not come on
send model number,is it gas or electric?check to make sure you have power where the cord connects to dryer and sent info so i can help you
Feb 24, 2010 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
169 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
