Question about HP LaserJet 4100 Printer
Dark Background on HP Laserjet 4100
HP Laserjet is printing a medium grey background on all pages.
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Posted on Jun 19, 2008
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
HP 2600n grey background
Most Original cartridges are starter cartridges that hold only 1/3-3/4 ink. Drum maybe defective, and this usually causes the grey or black in your printing. Cartridges may need replacement along with the drum. Hopefully this helps
Aug 13, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet 1012 printing black pages
dark background usually means the High Voltage Power Supply is malfunctioning.
replacement only.
Jul 05, 2009 | HP LaserJet 2420 Printer
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
May 17, 2009 | HP LaserJet 1020 Printer
Gray background
if you have a laser printer you may need to clean the printer or install a new drum cartridge, if it is ink-jet you will have to clean the bottom of the ink cradle it sound like you getting grey background from a toner/drum cartridge.
good Luck
Let em know if this helps.
Jan 29, 2009 | HP LaserJet 1200 Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
HP LaserJet 4100 Printer Logo
521 people viewed this question
Ben Johnson
