Question about Tascam DP01 All-In-One Recording Package Microphone
DP-01FX I'm trying to record the 8th track of an 8-track recording, and the VU jumps when it's not playing, but does nothing when the track is playing back or recording. I have the bass assigned to track 8 and the track is armed. What's going on?
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Posted on Jun 23, 2008
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
Jan 08, 2009 | Tascam DP01 All-In-One Recording Package...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
If anyone can help me out,please do!
Alternatively you could load your stereo instrumental track into a wav editor, then export each stereo track as a separate mono wav file which you can transfer via usb into you DP-01 and then on you DP-01 import those wav files into two separate tracks which you can pan hard left and hard right so they are in stereo.
Dec 28, 2007 | Tascam DP01 All-In-One Recording Package...
C.d tray
Hold down "Shift" and press "Exit" at the same time.
Nov 12, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
