Question about Whirlpool LSR5132PQ Top Load Washer
Washer filled with water but wont spin - Whirlpool LSR5132PQ Top Load Washer
  • 5,911 Answers
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Nov 14, 2010
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Feb 28, 2009 | Amana LW8203
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
