Question about Electric Jazzy 1115 Power Wheelchair
Pilot Joystick is fried Type # D49637/8A. Can I get replacement? What is the cost? Guy
  • 278 Answers
The Pride Jazzy 1115 originally came with the Pilot controller (Pride part # CTLDC 1030) and it has served you well. The manufacturer,Penny and Giles, is no longer manufacturing the Pilot. Fortunately, Pride is providing a new VSI controller 4 key 50 (70) Amp for the Jazzy 1115 (Pridepart number CTLDC1270 ) (manufacturer P & G part #D50148) for a retail cost of $1607. The new VSI controller will also need a new joystick mounting bracket assembly part #FRMASMB 4767 retail $30.
It is possible to have your Pilot controller rebuilt. There are many rebuild facilities that will sell you a reconditioned joystick (VSI or Pilot) for about $500 that will work on your unit. You can opt to send in yours for repair or reconditioning or purchase a reconditioned unit. Try MonsterScooterParts.com, TheAftermarketGroup.com, Wheelchair Wizard in Citrus Heights, CA.
The Pilot controller was a very robust unit but very expensive for Penny and Giles to manufacture. The new replacement VSI controller actually performs better and is more streamlined and smaller. The VSI pushbutton overlay (4 key) is very easy to use, The pushbuttons control on/off/speed increase/decrease. The replacement is easy to do as long as you remember to order the new mounting bracket assembly with the VSI because the old Pilot bracket will not work. All it takes to install is 2 screws to mount the control on the bracket, 2 plugs to connect, and 2 cable ties to secure the wiring. You may want to spray electrical contact cleaner into the plug receptacles on the electronics tray to clean them before plugging in the new parts. Hope this helps.
Posted on Nov 14, 2010
    Problem Solver:
  • 6 Answers
I am trying to fix one, it seems the regulators are turned on and off by the top board, but I am not sure how it does this. There are at least 2 regulators,. The 5V one marked reg1 is on the middle board that plugs into the bottom piower motor controller board. This is the one contianing the main CPU chip that gets marked with a 4 or 5 stamp. On the power board is another what seems to be a regulator. I tried to jump over it installing a LM7812 12 volt regulator, and while it powers on the device, does not seem to be the answer to reviving this device. So I am convinced the top board LED meter and where the Speed and Joystick connect, along with ribbon cable and the power pushbutton are somehow defective. I am trying to figure out where the 24v power distributes out to the ribbon cable. For testing safely I have 3 9V low current batteries which you can easily hook together to allow safe low current testing of the unit. Somewhere must be either a bad transistor which I see one on the button board, or must be a resistor open or cap shorted causing my issues. Has anyone else ever looked inside the controller to measure voltages and take notes on how they operate to aid anyone in fixing these outdated controllers? There seems to be NO resources anywhere from anyone. Manufacturers apparently throw them in the trash. Not cool when they could have valuable working parts, to fix broken ones, that are mechanically ok.
Posted on May 17, 2014
  • kb48694
    kb48694 May 23, 2014
    Now that I have spent some time working on it, its down to not sending 5v logical turn on/off latch to cpu board. There is an I.C. XAA812 surface mount that pin ?2 ? or some pin, I can see it toggles on and off (latched) with the pushbutton. However the signal is not getting down to the main board. This is or was because at one point the ribbon cable was messed up. I have fixed ribbon cable by cutting back bad section. However looks like either blown trace or blown 0ohm resistor
  • 692 Answers
Guy yep you can get another joystick. Cost? $800.00 or more depending on where you get it. Try e-bay they might list a joystick for your chair at a more reasonable cost Hope this helps
  • Ken Bouchard
    Ken Bouchard May 23, 2014
    Problem is on button board XAA812 chip latched 5v toggle is not making it down to main board. Suspecting blown 0 ohm resistor but havent located one. If someone had a schematic I could easily fix, alas mfr refuses to help. Money hungry.
  • Ken Bouchard
    If Ii ever do figure it out I will sharr the fix here for other techs. Simple fix will save hundreds of dollars. Where do the fried units go so they can be salvaged for people like me who cannot afford to eeplace them?
My jazzy blinks 7 time what does that mean?
Possible Joystick Trip
A joystick trip is indicated. Make sure that the joystick is in the center position before switching on the Pilot.
May need a trip to a service centre to plug the diagnostic box in to check for errors.
Mar 05, 2015 | Pride Jazzy Z-Chair Z-CHAIR
Schematic information on Pilot Penny-Giles controller for Pride jazzy or Hoveround MPV-4 etc.
I've never had much luck getting information like this for most joysticks, and have never gotten it for Penny+Giles stuff. You may have the best luck looking for a used replacement joystick on eBay or Craig's List.
May 17, 2014 | NRS Hoveround MPV 5 - Used Power...
My 07 Pilot key fob has quit working, replaced the battery with the CR1616 like the one that was in it. Still not getting a light on the key fob when I push button. Its fob fried?
If the little light doesn't work when you push a button, it's either dead, or fried. Be sure you put the battery in correctly too.
Mar 16, 2014 | 2003 Honda Pilot
Joystick
It's a known complaint in SE K510i. Get checked it in a nearest Sony Ericsson Service center. It may costs around $2 - $4 if not under warranty.
Mar 05, 2010 | Cell Phones
Pride 1121 wheelchair led 8bars flashing wont unlock batteries new ,the connections good. had just unloaded it ran it over a bump then it started flashing. Controler is bad or what? contiuity from motors...
trent618,
The 8 bar flashing lights indicate a possible control system trip. Without a serial Number or knowing which controller system you powerchair has, I will cover the common used controller systems for the model of powerchair you have.
If you have the Pilot or VSI control system the control system detects an internal problem within its self or the joystick, and I've seen it a couple of times when both the controller and joystick have an internal problem.
If you have the Pilot + or VR2 control system the control system detects an internal problem within its self and/or the joystick and/or a communications error between the joystick and controller. I've seen it once when the controller, joystick and cable between the joystick and controller being deffective. Due to the flashing lights and you have a Pilot + or VR2 there is a good chance the problem is the cable between the joystick and controller.
The possible solutions and repairs above will require the need for an authorized person to perform the tasks. Give the company that sold you the power chair a call, or anyone or different company which works on power mobility products as the part(s) needed will only be sold to authorized deallers or service providers.
Hope this helps, if so, please respond to this solution which will help others who may have the same question.
Thank you for using FixYa.
Flavadave75
Feb 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My shoprider creeps backwards on its own
Problem is your joystick is broken, I had the exact problem.
The plastic parts inside your tiny joystick is cracked due to abuse, likely someone pushed on it too hard, or banged it against something.. All it takes, is 50N, or 5 kilograms of force, to break it. It is a very delicate multi-axis inductive joystick made by Penny and Giles,
My advice is to replace the Joystick, which costs $200-300
A lot cheaper than replace the whole controller, which could cost $1000 or more.
Jun Lu
Oct 05, 2009 | Electric Mobility Shoprider Electric Power...
The chair suddenly lost power and now the lights flash continuously. The chair won't take a charge. A repairman tried fixing it at a local shop and said he put a new battery in and it sizzled. Now he is...
If he put in the batteries (2) properly, they should never sizzle. Some will emit a very minute spark when the final connection is made, but that is normal. There are fuses coming off of each battery to the power controller that will blow at 40 to 100 amps or so, depending on the chair; these will blow before the chair frying, or the circuit breaker will trip, or the controller will fry and all will be quiet on the chair, so I am going to say that the batteries weren't properly hooked up, otherwise on of the above items would have shut everything down. Continuous flashes indicate trying to start the chair while it is still on the charger, or with the joystick off-center. Make sure it is unplugged and notohing is resting against the joystick. If it's still a no-go, then you have either a joystick issue or controller issue. You will need to test those by replacing with known good controller/joystick, which a dealer should be able to do for you. Good luck.
Jul 17, 2009 | Jet 3 Ultra Power Chair
I have a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. asked a pool service guy come to fix, he could not move it too, and told me that i need a new valve....
your pool guy may be right but before spending any hard earned cash,remove phillips head screw in middle of on/off/pilot knob and remove.make sure there is no debris under knob.squirt spray lubricant along stem wait 10 minutes and lube again.replace knob turn to pilot position work it by pushing down several times.it may stick in down position so gently pry up.my success rate is about 70/30 for this technique
Jul 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
The joystick on my Kodak easyshare DX7590 does not work
Hello, I repair this type of Kodak camera and there is not an easy solution to your problem. It is the down fall of this series as they age. You will be better off to replace the camera than the cost of the repair.
Best Regards, Russell
Jul 07, 2009 | Kodak EasyShare DX7590 Digital Camera
Creative zen vision joystick
try ebay or email this guy
arnoldjin@hotmail.com
Dec 09, 2007 | Creative Labs Zen Touch MP3 Player
Electric Jazzy 1115 Power Wheelchair Logo
1,168 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
