Question about Frigidaire ATF6700FS Front Load Washer
Figidaire front loader washing machine ATF6700FS1 - control panel gives ERR message then alternates between "33" and 'PAU" message - Unplugging doesn't reset the panel. I think it thinks it's in midcycle. How to reset the panel?
  • Anonymous Mar 27, 2014
    the control panel is blank how do you reset the panel
Figidaire Washer Atf6700fs1 stuck on P
Posted on May 19, 2012
  • dodgethis_77 May 19, 2012
    What does that mean.
2 Suggested Answers
SOURCE: 2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Posted on Apr 24, 2010
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
My washing machine won't start
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Dec 29, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
349 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
