Question about Bosch Dryers
Everytime we put the dryer on, it stops after 5 minutes saying the filter and water is full, despite ensuring the filter is clean and the water is empty
    President:
  • 1,891 Answers
Try running the dryer off the vent / the filter may be clean but the air isn't getting out the vent and it may need cleaning .. mm hope this helps feed back pls . and thanks for using fix ya ..
Posted on Nov 16, 2010
My Miele dishwasher says E24 and will not complete a full cycle. I have cleaned the drain which had some food and fat in it. I've ensured all parts are enabled. What is next to overcome thi
E24 is the heating relay contact that´s probably defect, this would mean that the water is not getting hot.
I can´t remember just where it is locatet.
Dec 18, 2014 | Miele Dishwashers
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
Duet steam dryer soaked clothes and had alot of water setting in drumclothes were dry and wrinkled when i put them in the dryer 5 minutes later they were soaked.
Turn off the water or disconnect the water hose to your dryer.
Call your serviceman and tell him to order a new water solonoid for your dryer.
You can dry without the water hooked up to the dryer.
The steam cycles, however, will not have steam due to the absence of water.
Mar 23, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Dryer stopped working after 2-3 minutes
Go out and buy you a duct cleaner. It looks like a dome shaped broom. Clean your duct from the outside and if you can from the inside. Also if you use fabric softener sheets, clean your lint filter with soap and water periodically (every 3 months would be optimal) to remove the clear residue the dryer sheets can leave behind.
Good Luck!
Apr 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
53 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
