Question about Dewalt D55141 Heavy Duty 2 Gal, 150 Psi Max, Trim Compressor
D55152, left gage shows 40psi, right gage 100. Whats going on. how can i buy a manual? thanks
    Problem Solver:
  • 18 Answers
The right guage is the actual tank pressure. The left guage is the pressure for the air hose. If you turn the adjustment dial the air pressure guage on the left will go up or down. You should be able to go to the dewalt website and find an owners manual for this compressor. I personally own this compressor and it is a good one.
Posted on Nov 14, 2010
How to adjust headlights on a 2006 suzuki forenza?
left/right or up and down
most new cars do not allow left/right.
so not knowing whats UP> we cant help
you might read the FSM for 4 bucks like we must....
usa answer. on a USA forum
but if not here, other countries (europe) have auto aiming lamps.
so..... gee, where are you.
posted over 100 times.
https://suzukipitstopplus.com/Products/1066-2006-forenza-reno-service-manual.aspx
you can read the manual here, if car is USA car.
if not, you need to ask SUZUKI. where you live.
Apr 25, 2015 | 2006 Suzuki Forenza
How do I reset TPMS light focus 14
Use this if you're installing winter wheels/tires that have sensors already installed, or even if you are just doing a tire rotation. Not sure if this has been posted before. I tried searching but didn't see it posted anywhere. No need to go and buy the TPMS learning tool.
1) Make sure your tiresare inflated to the recommended psi. Mine is 40psi.
2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal.
3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo.
4) Release air pressure in the front left tireuntil you hear the horn honk. The LCD display should now read "Train right front tire".
5) Release air pressure in the right front tire until you hear the horn honk.
6) Repeat for the the right rear tire, and then the left rear tire.
7) You should now see "Training Complete" in the LCD display.
8) Fill your tiresback up to the recommended pressure.
Enjoy!
Nov 19, 2014 | Cars & Trucks
Truck run fine / started it in the am it had top end noise// oil is ok / i took oil filter of and cut it open // filter looks clogged i put a new filer and oil in and it still has top end noise when warm...
Sounds to me like the cam bearings are gone as that is where you get your oil pressure . most of those have to be pressed in after the motor is pulled out and tore down and going that deep i would go ahead and rebuild the whole motor while you have it out.
Jun 26, 2011 | Chevrolet C3500 Cars & Trucks
My jet pump has a 20 - 40 pressure switch but won't give any more than 30 psi. Whats wrong?
There are several causes for this to occur.
1. If it is a 20-40 switch right out of the box it may not be set correctly. I have had this happen. If it builds to 30psi and shuts right off without straining to build to 40psi adjust the Cut-Out pressure up to 40psi. There are two different adjustments on a well switch. One for Cut In / Cut Out psi and one for Cut Out psi.
2. Lack of head pressure being built by the pump can be the cause. This can be attributed to the wrong Jetting in the pump. IE: A shallow well jet/venturi on a deep well.
3. The pump may have a bad impeller, but the pump will generally really strain to build pressure and a bad impeller will be loud, like grinding at times.
4. Double check the pre-set pressure in bladder tank also.
RJ
May 28, 2011 | Fairbanks Ace 1 Horsepower Convertible...
What gauge exstention cord do i use for a lincoln weld pak 100?
Hi:
Weld pak 100 is a 120 volt unit, you will be ok with a gage 12.
Most 120V commercial extensions out there are 14 gage, if you want to buy one, choose no longer than 25 ft long.
With a 12 gage you can go to 50 ft. with no problems.
If this was useful to you please vote. Thanks.
Mar 27, 2011 | Welding Tools
How much power (kw/hr) does a D55152 use at full capacity?
Below you will find the power requirements for your compressor. I would recommend not to use an extension cord due to possible damage to capacitor. My dewalt a/c, with same motor, is actually using 17.5 amps right before shut off. Good Luck!
  • Drive: Direct
  • Horsepower: 2.7 MAX HP
  • Tank Size: 4 gal
  • Power Supply: 120V AC, 15 amps,
    >60 Hz, 2 pol induction motor
  • CFM @100 PSI: 3.8 CFM
  • Pump Speed: 3400 rpm
  • Tool Length: 18"
  • Tool Width: 18"
  • Tool Height: 16"
  • Tool Weight: 65 lbs
  • Oct 15, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
    Re fuel gage.
    the fuel tank sending unit is defective in your van, this has nothing to do with the fuel pump going out, this was a 100% incorrect statement by the shop that said this, but do understand that if you pull the fuel tank to repair the defective sender for the gas guage u might as well replace the fuel pump which also is in the fuel tank, they (the pump) are are getting worn out at about the miles you have on this car.
    Jul 01, 2009 | 2003 Pontiac Montana
    Manual for Emglo Air Mate Compressor
    Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
    Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
    Hook-Up for Paradagim Subwoofer-SB-100
    Just use the left input on the sub. The sub frequency components are generally across both channels, the left and right are to allow for easier integration with systems that have no specific sub output, a low pass filter is applied to the audio, left and right get mixed, and then feed to the subs internal amp. I advise for performance to use line level(low level-NOT speaker) inputs wherever possible. If you have any other questions, I am here to help ya. A "FixYa"rating would help my profile. Thanks.
    Happy listening
    regards
    Graeme
    Feb 09, 2008 | Yamaha RX-V659 Receiver
    Open Questions:
    Dewalt D55141 Heavy Duty 2 Gal, 150 Psi Max, Trim Compressor Logo
    239 people viewed this question
    Top Dewalt Hammering Experts
    John Trevino
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    richie46
    Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
