Question about 2wire (2701HG-B) Wireless Router
I used the wrong power wire(unknowingly) for it and when i plugged it into the box it smoked until i unplugged it. Does this mean it is fried or is it fixable, like a new fuse or something?
    Problem Solver:
  • 15 Answers
Generally speaking, fuses don't emit smoke <grin>
It's 99% certain that it's "fried" - repair cost would likely be --prohibitive.
If you got yours from your ISP, they may have a NQA (no questions asked) exchange program.
Otherwise... get another one. Craigslist is usually a good place to find 'em for less than retail.
PS: You might want to "tag" the power-cord so that you don't "fry" it again...
Posted on Nov 17, 2010
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
Can a dryer heating element smoke if dryer is not running?
Something fried and is shorted. Unplug this unit right away. There are a few sensors on this that could have overheated as they failed causing this smoke and smell, but UNPLUG UNIT!!! Then look at what has fried.
Aug 31, 2012 | Whirlpool Dryers
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
May 11, 2010 | InFocus LP 250 Multimedia Projector
Tried a power supply that was wrond voltage and
I don't want to sound mean or condescending but if you're good enough to repair what is wrong with that monitor you wouldn't be asking someone in here how to fix it. You just don't go pick up a soldering iron and start fusing parts in a monitor if you even find the parts at the local Radio Shack. If you smelled smoke and it doesn't come back on it's fried.
Dec 06, 2009 | Balance CM2019 19" LCD Monitor
Amp smokes but still works transitor looking thing is melted?????
954-443-1100 is the service department, sounds to me like your amp is slowly but surely frying itself. i am not sure putting a new transistor in it will help anything but you can try. There only around 15 dollars
Aug 23, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Fried my maxtor 3200 external hd
The drive will have to be slaved to another drive in another machine.
Apr 09, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
1984 ford 250 pickup replaced battery no power before i replaced battery, smoke came out apparently the cables were wrong? replaced starter cylenoid and still no power
If you connected the battery wrong, chances are you fried your main fuse box.  Check the main i believe 30 amp maxifuse and replace it.  Your main fusebox should be under the hood in the engine compartment.
Mar 05, 2009 | Ford F-250 Cars & Trucks
Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Did I fry it?
hi hamstermann,
Fried like bacon is about all I can say.
Thats alot of volts going through something like that.
Not sure what a 7000 series costs,
but hopefully you have warrenty to cover it.
Just between you and me, dont tell them you messed up the cord.
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
No power to Compaq Presario
There were several recalls on Compaq's ac adapters and batteries that caused fire to units...
Check this out
http://www.consumeraffairs.com/recalls04/2006/hp_batteries.html
I would also check with compaq about your problem. They were replacing and repairing the units free of charge due to the defects. I would check with them
Hope this helps you
Oct 21, 2007 | HP Compaq Presario R4010US (PX352UA) PC...
2wire (2701HG-B) Wireless Router Logo
97 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
