Question about BenQ FP731 17" LCD Monitor
How to connect external speakers to BenQ E2420HD monitor and how to use USB port
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
How to connect Logitech 2.1 external speakers which has 3.5mm green color male pin to BenQ E2420HD monitor?
You can connect the 3.5mm male pin at the left side of the monitor(if you're facing the front panel) it's located under the two USB ports( see "G" from the bottom Image). You may also use the line out port available( see "A" from the bottom image)
If you need the list of ports available you can take a look at the picture provided below:bourngenius_0.jpg
Hope this helps. Please check the manual for more info.
Nov 15, 2010 | Computers & Internet
How to use USB ports in BenQ E2420HD monitor? Can I connect pen drive..........
The USB ports on the Benq monitor is a USB hub. Connect a USB cable from the USB port on the computer to the input USB port on the Benq.
Then you can connect any USB devices to the USB port on the Benq and the computer will see this device.
No sound
no if external speakers work that means that the sound card is absolutely fine>
now let me tell u the computer itself doesnt have any in built speakers>
either u connect external speakers or the monitor that u use should have speakers built with it> then u connect the monitor to the computer then also use a thin sound cable from the monitor to the back of the computer on the green port
Oct 07, 2009 | HP Computers & Internet
Wanting to use tv as monitor with benq a52 v03 joybook
Yes, you need to press the key combination for your laptop to direct the video output through the external VGA port. It varies by laptop, but it usually involves the use of the Function (Fn) key and another key like F4...look for a picture of a screen in the same color as your function key.
Jun 15, 2009 | Computers & Internet
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
Need help getting audio to play on my HP 2009m monitor which is connected to my HP laptop.
The speakers on the monitor will work only when the sound output from the laptop is connected to the monitor speakers. Please make sure that you connect the cable from "Audio OUT" (generally Green colored port where you connect your headphone or external speakers) on the Laptop to the "Audio IN" port on the monitor.
Please let me know if it works.
Thanks and Regards,
Srinivas
Apr 21, 2009 | Computers & Internet
PC shows no disc in drive E
is this because i used the usb cable for another devide?
- i dont think so. the usb cable that comes with the benQ camera is the usual usb cable. i used it for other devices and still works fine with my camera again. i even used another usb cable from other devices in camera and it works fine.
is it a virus maybe?
- well you can try inserting a different device in that usb port, now if it still cant see it, its probably busted. all your usb ports are on used? wow! how about you try taking some of it out and check those ports for your camera.
Nov 26, 2007 | BenQ DC3410 Digital Camera
No Audio?
Have you connected the sound cable from your soundcard on the computer to the audio port on your monitor (it's underneath).
I only ask because it's often missed being where it is.
Anyway, hope that's all your problem was.
Nov 02, 2006 | BenQ FP71E 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
516 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
