Question about Kenmore Washing Machines
Kenmore washer model 2120. Makes a quite different noise & takes longer to wash than my old machine. Is this normal?
dididsaythat
  • 291 Answers
SOURCE: Kenmore 80 series top loading washer won't agitate and is noisy
Sounds like u may have broken the coupler gear between the motor and transmission... the replaced the belt with these gears on this model... But should go fill & pumb water out and NOT spin Or agitate... IF these gears or broke or stripped... heavy loads like u  said would do this... recheck and see if wash will pumb water out But will NOT agitate or spin.. IF so the above is your problem  and is Not to hard to repair  or much money
Below is a pic with the motor remove the white piece in the middle is 1/2 of the gear system with a rubber piece in the middle (not there)  and another like gear on the motor
sounds like these gears may be broken or stripped on your washer
Posted on Oct 27, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 91 Answers
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Posted on Jan 04, 2009
I bought a Kenmore Elite washer a little over a month ago. It is a beautiful machine, it is also the worse washer I have ever had. It doesn't get the clothes clean & wrinkles so bad th
Sears sux! How old is that unit? Because if it is quite new then you bought a basic model, and sadly that is what you paid for. Let me know.
Sep 22, 2014 | Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
Won't spin and loud noise
Kenmore washers could hold a few problems. First, without a model number you don't know who makes it. See, Kenmore does not make washers, they have someone else make them such as Whirlpool or Frigidaire. More that likely you have a Whirlpool (which is a good thing). What you are probably hearing is the coupler of the machine broken. A coupler is what replaced a belt in the newer machines. This piece is installed in between the motor and transmission. If it breaks it makes a loud rattle/grind sound. It is possible that the transmission is also the culprit. However, this noise is entirely different. A bad transmission generally makes a loud screech noise. If this does not help, please post a model number of the washer and I will gladly further assist you :)
May 28, 2010 | Kenmore Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
212 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
