SOURCE: ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
SOURCE: Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
SOURCE: Not printing black ink after replacing cartridge
Unfortunately I have no idea which compatible cartridge you're using so it's difficult to provide a definite solution. However a few things to consider:
1. The cartridge needs to have a clear vent hole so if you haven't removed tape or a plug from a hole that was indicated in the instructions, you need to do this.
2. Try removing the cartridge and then touching the exit port on the cartridge with a Q-tip (cotton bud) to see if the ink flows to the cotton. If it doesn't you need to replace the cartridge.
3. Check the cartridge is sitting properly in the printhead.. The interface between the printhead, rubber grommet and the cartridge exit port is very important and the cartridge needs to sit in this properly.
My guess is that the compatible cartridge is not up to the job and you need to consider getting an OEM (Canon original) instead.
You may want to think about finding a refill kit and using the Durschtich (German) method of refilling using bulk ink and a chip resetter instead of compatibles.... Nifty-stuff forums have a LOT of information on this subject so it's well worth a look.
Hope that helps.
Martin
SOURCE: waste absorber is full in canon iP4200?
Follow this instruction:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 of times.
5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
SOURCE: Canon ip4300; new printhead and PGBK ink cart but it won't print
Perform Print head clean should do the trick. May have to repeat.
