Question about D-Link AirPlus DI-524 Wireless Router
D link wireless router problem.
Hi
I have a d link wireless router it was working fine but we had a power cut and now it just dos'nt work do you know what might be the problem?
many thanks.
  • 298 Answers
You can try this. turn off the router and the modem. Leave them off for a minute. Then turn on the modem first, wait for the lights to stabilize and then turn on the router. this will reboot your network. This will make the router and the modem synchronize again.
Posted on Jun 18, 2008
The defalt log in for a d-link n 150 is not working..the router was workin fine and now i cant reset.what do i do?
default password for dlink devices is either password or 1234.
make sure when you reset the device you hold the reset button in for 30 seconds or longer while powered on.
Mar 10, 2012 | D-Link Wireless N 150 Home Router
I have installed 7ultimate and cant access my wi-fi .i have disk but it wont let me use my password says dos nt match. pressed reset to no avail
Make sure that the wifi security that you used on your router matches that of the security you are trying to setup on your new Windows 7 Ultimate box. If the security doesn't match up, it will tell you that your passwords don't match as well.
Aug 27, 2011 | D-Link DIR-615 Wireless Router
DIR-615 , power led blinks always, wifi and internet not working
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
5. check the power adapter it may be faulty.
Apr 28, 2010 | D-Link DIR-615 Wireless Router
Fsd7230-4 my router connects with my laptop but does not get to the internet.. my modem works fine when i plug directly.. what am i missing.
I assume your laptop is connects to the router but is not getting an IP address - and that is causing the Internet failure.
Test this by connecting wireless then: Start - Run - type "CMD". In the DOS window, type IPCONFIG /ALL
If you get an IP address of 169.254.x.x then your router is not providing your laptop with an IP Address.
Log into your router and enable DHCP on the Wireless clients
Nov 20, 2009 | Belkin (F5D7230-4) Router (587009)
Ipconfig is not working on my laptop
Check what is the ipaddress,tried to shut down the laptop and drain flea power.Then check if the laptop can detect wireless connection. Then ping website in command prompt.Try ipconfig /release and then ipconfig /renew. Try connecting wired internet connection to check if issue with operating system or browser or wireless connectivity.
Aug 17, 2009 | E-Machines eMachines Desktop PC
Dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Aug 07, 2009 | D-Link DIR-615 Wireless Router
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Hi i recentley bought a new dell inspiron 1501 model and the internet has stoped working all together.All it ever say's is cannot communicate with primary dns server(66.82.4.8 this really causeing me alot...
welcome to fixya
Make sure you are hard lined into your router before doing this
might want to try this if you have vista at bottom of the start is a search bar type msdos
it will find a short cut double click it and you should be at dos
once there type in ipconfig hit enter
then type in ipconfig/release hit enter
the type in ipconfig/renew this should rest the dns to your router
Jul 25, 2008 | Computers & Internet
Belkin n1 wireless router no security!!
Check ip address of your pc. Go to DOS Prompt, type ipconfig then click enter. Look for DEFAULT GATEWAY(that will be your router ip address). Open your browser and type the default gateway on the address field(example: 192.168.1.1). That will take you to your router page. You can set up security there.
Mar 15, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
