Question about Whirlpool Dryers
The controllock is on How do we reset it the vents have been cleaned
  • 4,323 Answers
Hi
To reset the control press and hold the END OF CYCLE button for 15 seconds. Hope this helps...please post back for further assistance.
Daniel
Posted on Nov 14, 2010
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Apr 26, 2012 | LG DLG5932W Gas Dryer
Its not drying the clothes and is taking longer to dry. is there a way to reset?
Dryer Repair. In most cases the problem lies in the vent. Your vent may have partially blocked with lint. The first step is to have vent cleaned out by a vent cleaning company or else buy the "whirlybird" drill attachment and do it yourself. Of course, this is assuming you are getting heat inside the drum. Hope this helps,
Sep 29, 2010 | GE Profile Harmony DPGT750EC Electric...
The projector lamp turns off after one hour.
Very likely the air vent is block or you will need to clean the air vent. The system track the hours of usage and when it is time to clean the air vent filter it will stop working. A clogged air vent will make the temperature of the equitpment rise. To protect the circuits and projector expensive light component it will stop working automatically. After cleaning up the air vent, see the manual how to reset the clock/timer for air vent cleaning timing, so that the lamp would not turn off.
Aug 10, 2010 | InFocus Proxima DP5900 Multimedia...
After 2 mins on the bulb goes out
Need to change bulb and reset the lamp timer. When was the last time you clean the air vent filter. Clean it and reset the air vent filter cleaning timer
Aug 10, 2010 | 3M EP7630LK Projector Lamp for MP7630,...
By mistake I pressed the ControlLock button instead of the power button. I cannot get the control lock button to release and turn off now. How can I get the Control lock button to turn off?
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 21, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
The controllock light is on and the machine won't start
you likely have a bad door lock assembly and the machine is not registering the door is locked and therefore won't start.
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Model PYE2300AYW Heats for short time
In most every case i have seen this happen, the dryer is connected to flexible venting. Flexible venting is the worst thing for a dryer. Rigid aluminum only. If your element shuts down that fast, it is definitely an air flow problem. Remove the front, clean out the lint screen housing from the spout to the blower, all the way to the lint screen so that it looks factory clean. The venting must be absolutely clean as it was the day it was put in new. The outside application, whether it is louvers, vent flapper, or ball vent, must be clean and operable as a new one. Once again, my suspicion is the venting as it is most likely a flexible type of venting with either excessive length or restricted flow. A dryer can only be vented for 30 ft. counting 5ft for every elbow and 5ft for the outside application. But the flexible equates as this...for every 1 foot of flex you must add 5 foot because of air restriction. I am surprised that the non resetable fuse has not blown yet. ( it will, trust me.)
Mar 31, 2009 | Maytag PYE2300AY Electric Dryer
ControlLock
It seems monitor 's problem plz check memory ic and command ic for fault.And check all components that is placed near front panel keyboard's buttons.normaly it is the problem of command ic and memory ic.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 23, 2008 | SAMTRON 55V 15" CRT Monitor
Dryers Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
