Question about Toshiba (TLPLMT20) Projector Lamp for TDP-MT200
My toshiba projector tdp-mt200 keeps shutting off after about 20 minutes or so. I thought it was the lamp so I replaced it and it worked fine for about a day and then the new lamp blew up the glass exploded. so i put the old lamp in and it shuts off again after 20 minutes i lose the picture and projector stays on.
  • marcwhaling Nov 14, 2010
    why would the new lamp shatter and the old lamp just shut off then.
  • Toshiba Master
  • 12,061 Answers
You need to look for your thermal fuse and replace it, it is old and is failing after being heated for a while The glass exploding.. well that's a worry, however bad, or low quality or counterfeit units can do this.. Either that or the power supply is sensing some fault and is shutting down,you will have to troubleshoot, in that case using the manual.
www.givemefile.net/smanuals/projectors_home.../file/31157.html -
www.aboutprojectors.com/pdf/toshiba-tdp-mt200-manual.pdf
Top service and repair manual below user manual... use these to find and repair your fault.
below is the master Google link for manual
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=tdp-mt200+service+manual
Posted on Nov 15, 2010
  • 22,219 Answers
The thermal switch is cutting in ,only solution is increase ventilation ,by placing a fan next to it to keep it cool ,or modifying it and fiting a fan inside it in some way shape or form
Posted on Nov 14, 2010
We have Toshiba MT200 projector mounted on wall with unit inverted. My question is how do you flip the image 180 degrees on the unit?
use the onboard menu on the projector it should have the option for this just check through it completely :) hope this helps
Feb 25, 2011 | Toshiba TDP-MT200 Multimedia Projector
Timer reset
This may work. It is procedure for TDP EW25colmkillpaul_3.jpgcolmkillpaul_4.jpg
Oct 04, 2009 | Toshiba TDP-MT200 Multimedia Projector
Toshiba MT200 videoprojector won't start
if there are no leds lit on the top, the power supply is gone. if there are leds on the top, which ones, are they blinking, how many times, and what color?
Sep 01, 2009 | Toshiba TDP-MT200 Multimedia Projector
Lamp
Hi Striker 53
Yes , a flickering image and dimming is a very clear indication that the lamp is going.
To make 100% sure and to give you some peace of mind - take out the lamp and you will either see vein like looking marks on the lamp or discolouration or even that there is a bubble at the end of the lamp's shaft.
Do keep in mind that a lamp normally gets a rating of say 2000-3000 hours , but that is only a estimate from the manufacturers factory. I've had lamps that had less than 300 hours on them , that needed replacement.
Once you replaced the lamp , remember to reset the lamp timer.
Apr 20, 2008 | Toshiba TDP-MT200 Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Lamp
There are some on ebay.
Nov 09, 2007 | Toshiba TDP-MT200 Multimedia Projector
Toshiba (TLPLMT20) Projector Lamp for TDP-MT200 Logo
250 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
