Tascam CD-A700 does not recognize disc most of the time
When you place a disc in the tray of my tascam CD-A700 it does not recognize
the disc is present (NO DISC) most of the time. Sometimes it does. Hopefully , I can find an easy solution; however, if not if not, and If you recommend repair, to whom do I send it?
    Problem Solver:
  • 16 Answers
I had the same problem. I took the stereo apart and isolated the CD changer. I then gained access to the lens and using a lens cloth which came with my glasses, I wiped the lens being careful not to use too much pressure but speed. I put it all back together and doesn't give me the "no disk" message and moreover it plays great. Glad I took the time and trouble to disassemble the unit. All I can say is...that it worked for me. Don't use any other cloth other than a lense cloth though, or you will scratch the lens and it will become useless.
Posted on Sep 18, 2009
  • 2,071 Answers
The problem of "no disc" is in the lense .The lense is already defected you better change it.You better go a certified service center.
Posted on Jun 19, 2008
Cd-a700 laser pickup
I don't think they are available anymore. You could get the definite answer by contacting New Jersey Factory Service in Emerson NJ. They work on that stuff all the time. The guy's name is Russ.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
www.njfactoryservice.com
Jan 24, 2013 | Tascam CD-A700 CD Player
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
Won't recognize cd
If it will not recognize the cd and you tried to clean the laser eye, then you should contact Tascam to find a local service center to change the transport.
Dec 14, 2010 | Tascam CD-A700 CD Player
I bought one on ebay and it is in excelent shape however the cd player doesn't recognizes disc. I opened the unit and it seems to be working ok but says "no disc" any tips? Henry
All you can do is clean the lens and if that does not do it at this point Russ at New Jersey Factory Service has said they don't support that model anymore.
Oct 18, 2010 | Tascam CD-A700 Single Dual Cassette Deck
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
Replace Tascam DP-01FX/CD -- the CD R/W won't work
I don't think there is a problem with your CD writer.  You have not inserted the type of disc your write drive requires.  You must use a BLANK "AUDIO CD-R".   Check your instruction manual concerning the type of disc required.  Data CD-R's will not work in this type of drive.  if the disc has "DATA CD-R" or "700"mb or "800mb" printed on it it will not work.  audio CD-R's are not as common and are a bit more costly.   They are the only type of disc that will RECORD in your drive.  Regular audio CDs should play in your drive.  I hope this solution will work for you and I wish you every success! Michael Mittelsdorf
Nov 03, 2008 | Tascam DP01 All-In-One Recording Package...
TASCAM 2448 xp drivers
I have a tascam 2488mk11 whit no driver cd also .Tascam is pulling a scam
Jul 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
186 people viewed this question
 Grubhead
Grubhead
