Question about Whirlpool LSR7333 Top Load Washer
Adgitator doesnt aggitate. Sounds like some gears or something are stripped out?
  • 5,911 Answers
If the washer is running, but the agitator is slipping, then you may have worn agitator dogs, or a loose agitator bolt. The following link explains what the dogs are, and how to access to acces the bolt and replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you may need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided. If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on Nov 14, 2010
Keurig expresso wand doesnt spin
Sounds like stripped gears for the wand drive. Plastic gears. If the wand gets jammed, it will strip gears. Hope you bought the extended warranty, I'm not sure if spare parts are sold.
Oct 27, 2015 | Keurig Coffee Makers & Espresso Machines
SOUNDS LIKE LOOSE CHANGE UNDER DRUM.CAN DRUM BE REMOVED TO GET CHANGE OUT.
Yes, First pop the lid up with a flathead screwdriver. You'll see two clips between the body and the lid panel. Once you get the lid up take the tub cover off. It just snaps on to the tub. There is a plasctic cap on the top of the adgitator that covres ther adgitator bolt. Remove it and remove the bolt, and take off the adgitator. This will expose the 6 bolts that hold the basket on. Remove them and the basket will come off, and you can get to anything in the tub.
Jan 30, 2011 | Maytag Bravos MTW6600T Top Load Washer
Drill works perfectly in gear 2, but its like gear 1 doesnt engage properly, it just rattles and doesnt rotate when it comes under even slight pressure
This sounds like stripped gears, happens if you switch the gears while unit is running. you have to disassemble and replace what is damaged. Not always very easy for a home repair, consider a tool shop for this task.
Oct 11, 2010 | Milwaukee Tool Milwaukee 2601 22 18V Li...
My kenmore 70 series will not agitate. It rocks back and forth but center doesn't move. Now if i put my hand on the top of it and press it down it does just fine. Is there a gear that may be broke in the...
Not a gear, Four peices of plastic.  They are about $2 and really easy to replace.  Take the cover off of the top of the adgitator with a flathead screwdriver, and there will be a bolt underneath it.  Take the adgitator off, and seperate the two halves.  There are four pieces of plastic known  as dogears because of their shape.  Replace those and it will work
Dec 04, 2009 | Refrigerators
My Kenmore model 80 washer won't aggitate but spins and drains without issue. The aggitator tries to move but acts like there is a gear stripped or something.
you will need to purchase an agitator replacement kit for your washer and, the clutch will need to be replaced as well. these components are damaged and, replacing them will restore your units agitation functions.
Jun 07, 2009 | Kenmore 15944 Top Load Washer
No aggitation or spin, high pitched noise.
Sounds like you have a broken motor coupling , empty the unit , tilt it back against something so you can get a good look under it , the motor is in the middle of the pump[front side] and the gear case[back side] the shaft comes out of both ends of the motor , look for the part that connects the motor and the gear case , it is a small round rubber and plastic piece with prongs , all of the prongs have most likely broke off. , replace this and it should be fine. let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Need to replace the adgitator dogs
Nothing else needs to be removed. place the agitator on the floor, step on the sides of the bottom of the agitator, grab the top section of the agitator and pull, the sections will separate. hope this helps.
Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
The aggitator (sp?) isn't turning...the rest seems to be working (spin & fill). How do I fix it and is it worth fixing? Model LBT6133A Whirlpool Washer
Go under the aggitator inside the tub and pull out the aggitator it self and check out see if the teeth are strip,If the teeth are strip on the aggitator replace it. If is on the other side then it's not worth repairing. All you need to do is just pull on the aggitor from the bottom.
Apr 26, 2008 | Washing Machines
Whirlpool LSR7333 Top Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
