Question about Cycling
Left pedal stripped out - Cycling
    Guru:
  • 347 Answers
There are only two realistic solutions for this.
1) Replace the left crank arm that the pedal attaches too.
2) Insert a helicoil to replace the threads.
If replacing the left crank arm is not possible, then go the helicoil route. Either way this is best done through a bike shop as the helicoil system requires a good amount of mechanical knowledge and some specialized tools.
Posted on Nov 18, 2010
Model :x 3519 right pedal stripped
If it is the pedal's threads that are stripped just purchase a new pair. If it is the threads on the crank that the pedal goes into then either replace the crank arm if it's the left side or find a bike shop that can install a "Helicoil" to repair the crank. Threads will be stronger than the original
Jul 31, 2017 | Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
How does a helicoil for stripped crank arm work?
I would just stop by a welding shop and have them weld the pedal arm on. You can buy another whole bike for what it costs to get a helicoil like that done. If it's the left hand thread, impossible.
Nov 25, 2013 | Huffy Blackwater Men's 26-Inch Mountain...
The bolt (screw) attaching the right pedal was stripped. Where can we purchase a replacement? Thank you.
If the threads in the crank are stripped it will likely need to be replaced as well as the pedal. They come in pairs. I advise you to get the bike to a real Bicycle Shop because special tools are required. BTW: the left pedal is LEFT threaded.
Aug 11, 2011 | Motobecane 400HT
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
My right pedal is stripped. how can you repair/replace the part the pedal screws into?
If it's stripped the crank arm will need to be replaced. It's probably more expensive to fashion a repair with helicoils and taps, even if you COULD find a left-handed one for the left side.
Get on your favorite search engine and look for "(your brand of crank) (size)" or just take it to a Bike Shop and let them deal with it. You would need special tools for crank removal anyway.
http://www.parktool.com/blog/repair-help/categories/crank-service
Jun 14, 2011 | Dynacraft Cycling
I have a rb260 and the left pedal was threaded on crooked and now it's stripped and will not stay on.
The left pedal is a left hand thread.
if it is stripped the only fix is a new one, and possibly a new crank as well
Jan 22, 2011 | Cycling
I can not get the peddle off the crank. peddle part number fc-m500 crank set shimano sg
You have to have a pedal wrench and they pedals have a right thread right side and a left thread the left side. The right side is the chain side, to tighten either one, you put the bike in front of you and turn the pedal wrench towards you to tighten, to loosen turn the wrench to the rear. This is very important, do it wrong and you strip your crank arms. Pedals are marked R for right side, L for left side. It is important to know this information. Most manuals do not tell you.
Sep 20, 2010 | Shimano Cycling
Sustain pedal on Yamaha DGX not working
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Cycling Logo
108 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
