Question about Asko W620
Asko 620 not spinning and not agitating
I replaced brushes 6 months ago and it worked fine.
But now it wont spin and not agitating.Will fill with water and drain but will do nothing in between.I took out motor and looked at brushes,they still look new.
Drum will rotate easily,It will not go to any code,just will not do anything after filling with water.Is there anyway of testing the motor when it is out?I will go and take motor out again and clean off brushes but they did look fine before.
  • merville Oct 07, 2008
    I checked each of the brush and it seems the left brush with the pin protruding out prevents the larger surface of the brush from making full contact with the armature. Will it matter if I file off this pinlike brush so the larger surface does make full contact with the armature?
Clean armature and replace brushes. When you remove the brushes the shut a small pin like device maybe protruding from the brush tip. this is a sure clue.
Posted on Sep 19, 2008
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
GE washer wont agitate or spin ?
This could be because the carbon brushes in your motor are worn down. One will need to check the motor to be sure.
The carbon brushes apply electricity to the motor via a split ring comutator.
Over a while the carbon dust can create a short circuit. The motor needs to be looked at and cleaned. Possibly may need to replace the brushes.
Take care!
Apr 28, 2012 | GE Washing Machines
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
Asko 10505 not agitating or spinning
not a solution, I have had the same problem due to family members overloading the machine, in fact I have it now which is why I am on here. Previously I fixed it by cleaning the deposit left on the rotor caused by the brushes. It worked before but not this time maybe the brushes are now too worn. This is my second set of brushes I replaced a set after about 10 years of use. From memory there is not a huge difference between a completely new motor and a set of brushes so I may go that way now as the machins is around 15 years old
Aug 02, 2009 | Asko W6021 Front Load Washer
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
Basket wont spin, still agitates and drains...
  1. Check the carbon brushes on the motor. they are probably worn and easily replaced..
Nov 27, 2007 | Washing Machines
Washing Machines Logo
479 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
