Theres a message saying catridge missing or not detached
I've got a HP laserjet 1012. I have placed a new print cartridge 12A black, but my computer still give the message "toner empty" and my printer have still the flashing red light. What i have...
I wont think so that there is no toner level sensing in 12a catridge, messaige might be catridge missing or incert catridge.. remove back door see down right side sensor which sensing the catridge presence, check sensor flag dislocate/spring dislocate/broken correct it, if sensor is dusty clean it... Best of luck
Sep 09, 2011 | HP LaserJet 1012 Printer
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer X5070 KEEP ON SAYING THAT THE RIHGT CATRIDGE IS MISSING, WHILE THE CATRIDGE IS IN SIDE. I CANNOT GET CATRIDGE LEXMARK 21 THEY SAID I CAN USE 28 AND IT SAYS IS AN INCORRECT CATRIDGE. PLEASE HELP...
Sounds like the sensor area may be dirty, to the 21 cartridge. try lightly scrubbing that with a very smooth cloth or whatever you have. its the area where the "chip part" of the cartridge must meet. that or new print head because its too worn, pending on how long you have had it for.
Dec 04, 2009 | Lexmark X5070 InkJet Printer
Black cartridge missing message
the contact is bad and you will have to replace the catridge. I recommend just blowing it instead of using damp cloths, too late now. If you replace the cartridge it will take care of your problem.
Oct 08, 2009 | Dell 922 All-In-One InkJet Printer
My hp 1310 says no colur ink catridge found.
No
some model hp deskjet all in one used duel cartrdge because it is a color popier
Jun 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Dell 725 USB printer says catridge not present when it is
i think you will have to take the printer to the service center as it needs servicing, there might be a problem with the cartridge holder
May 03, 2009 | Dell 725 InkJet Printer
Missing catridge or door open
when you put new 12A cartridge. you have to align it trough by the option.
Feb 17, 2009 | HP LaserJet 1018 Printer
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Ink cyan message
???????????? Brother didnt compute that first message (seal off)!
For the second message have a look at cyan. Its empty, too ;-)
Feb 20, 2008 | Brother MultiFunction Center MFC-440CN...
22 people viewed this question
jasbo
jasbo
