Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
My Fein won't turn on without rapping it on the floor ! I turn the switch on and it won't run until I tap or rap it and will shut off during operation. I'm sure there's something loose , but should I attempt it or take it back for repairs . Last time I tried it , it woudn't turn on at all . My wife purchased it earlier this year from a TV infomercial .
  • Fein Master
  • 1,793 Answers
ELECTRIC FIELD (and all the push contacts are most of the time the problem the cause by this machines , dirt in the switch (the switch is made to disassemble to clean it sometimes .little screwdriver neccesary .
Posted on Jan 01, 2016
2 Suggested Answers
  • 8 Answers
SOURCE: need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Posted on Jul 19, 2012
I filled my dust bucket too full and its jammed on my Dyson 37.?
Gently rap and tap the sides while holding the release. Do NOT force it. If you do the result may be damage to the clasp and release. Use patience. In the future try to be more aware of the level of debris in the dust bucket. Good luck!
Jul 21, 2014 | Dyson DC14 Hose Assembly 908474-37
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
FEIN 9.55.13 WILL NOT TURN ON. SWITCH? BRUSHES?
replacement parts for that model can be found at amazon, click here and take a look: Amazon com fein vacuum parts . Have a nice day
Sep 12, 2011 | Fein 9-55-13 Turbo II Bagged Canister...
Hi my dyson hand held dc 16 runs for 10 secs then for 3 secs until you let it rest, then it does the samething again
take it apart and look for some trash might be rapped around the motor,because if the motor heats up it will shut down to keep it from burning up
Mar 31, 2011 | Vacuums
The belt is intact but the aggitator doesn't spin anymore. Had a horrible rubber smell, went to change belt. Not the problem. Anyone know what could be wrong? Dirt Devil bagless w/dirt indicator
Even though your belt is intact it still could be worn. if you tilt the vac up (roller off the floor and the roller spins, replace the belt. on most vacuums the life of the belt for optimum performance should be 9- 12 months. If your vac has a carpet / bare floor selection, check to make sure it is in carpet mode.
Oct 10, 2009 | Vacuums
Dyson all floor vaccum no suction when hand held wand is turned on... doubled checked for cracks in hose -- none took house off unit to check for blockage --- none.. suction works fine when using as normal...
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
Jim
Jun 09, 2009 | Dyson DC14 All floors Bagless Upright...
While using the vacuum, the brushes stopped turning.
check the drum. Hair will rap around the axxel and stop the brush from turning. Cut this hair with a razor and place a small drop of oil on the end of the axel.
May 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
Jan 17, 2009 | Eureka 431A Optima Bagless Upright Vacuum
THE MOTOR KEEPS RUNNING
Could be 2 reasons, since you changed your bag and this started happening, 1 is that you the aut/manual switch got bumped to manual. In manual it will run until you unplug it or set the switch to auto. #2 is there is a relay that has stuck in the on position. Sometimes rapping on it will jar it free, most times t has burnt contacts and will keep doing this, so replacing it is best.
Jun 17, 2008 | Broan-NuTone CV750 Central Vacuum
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
127 people viewed this question
Top Fein Vacuums Experts
JoeVacs
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
