Question about Line 6 Fbv Deluxe Pedalboard
How do you calibrate the volume and expression pedal
    President:
  • 1,138 Answers
You'll find it here:http://line6.com/community/docs/DOC-4499;jsessionid=15493B7A2C4B9635CC2C820C7274E79B
Posted on Nov 16, 2010
Do I need to clean my noisy FV500L pedals or is there a less intrusive fix?
I suggest a shot of DeOxit 5 into the pots to clean them up. If not, replace thepots.
Mar 30, 2017 | Denon Music
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
Volume pedal will not stay in up position
Worn teeth on belt or guide is slipping. Tighten or repalce as needed.
Aug 18, 2014 | Roland Boss Fv-500l Stereo Volume...
Yamaha FC7 Pedal not operating
Make sure the shaft is turning the volume pot, if so, then potentiometer is bad OR has a bad connection. The cord is probably the cause from being pulled on or the plug needs re-soldering.
Feb 20, 2013 | Yamaha FC7 Pedal EXpression
Hi. I have bought a Behringer Bass Synth BSY600 and a Boss FV-300L Volume / Expression pedal. Both work on their own but i can't get the Expression pedal to work with the Bass synth. The expression...
The FV300l WILL NOT work tying it into the EXP of the BSY600. What you need to do is to run your guitar into the IN of the BSY600 and use TWO audio cables from the BSY600 output, the OUT and the DIR out and run those into the two IN's of the FV-300L. Then use whichever function by connecting the two OUT''s of the FV-300L to two channels of the mixer or a two channel amp so you could proportion the BSY600's effects as desired. You could also just use whichever out from the FV-300L you want which originates in the BSY600. The BSY600 is made to use an expression pedal that is a single TRS plug which is simpler, but you can use your FV-300L as I have described just as well, it just can't use the EXP input of the BSY600.
Jun 22, 2011 | Behringer BSY600 Bass Synthesizer Ultimate...
Hi I have a Behringer Fcb1010 and I want to programme one of the expression pedals as a volume pedal but am unsure how to do this?
I have Behringer Fcb 10 10,but i want to know how expression pedal volume work when connect with GR55.
Feb 11, 2011 | Behringer Fcb1010 Midi Foot...
I just bought an M-Audio Keystation 88ES. I have a used Behringer expression pedal. The pedal works fine in the sustain input, but when I insert the jack in the volume input it cuts all power to the...
If the power goes off when you plug in the pedal, the pedal LIKELY has a short in it between two of the three connections at the plug.
Firat, try putting the pedal plug in BEFORE applying power.
Likely the pedal presents a pot or volume control that will have like 5 volts across it an the wiper returned on the same cable. If the wiring configuration is wrong OR if the plug goes through a period of shorting the 5 volts out during insertion that will cause a problem...
To troubleshoot, move the pedal to half way and these with an ohmmeter for shorts between ANY two of the three connections.
Jan 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
Where should the Zoom G1X go in a pedal chain?
From an electrical engineering standpoint, an expression or volume pedal should be near the end of the chain so that the other effects don't try to process very weak signals when the volume is very low.
This gives better signal to noise ratio.
May 11, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Low volume allen organ adc 4600
IF the expression pedal uses a lamp and light-dependent-resistor, check for burned out lamp at the pedal.
Sep 06, 2009 | Music
Line 6 Fbv Deluxe Pedalboard Logo
117 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Larry Stiles
Larry Stiles
carey w mason
carey w mason
Are you a Line 6 Music Expert? Answer questions, earn points and help others
