Question about Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
My saw threw a blade . I took it apart to put the blade back on I have tried everythingbut the blade ,which is the proper one isI about 1-2 links too long. this is w/ the tensioner all the way out. Any suggestions?
  • bglehr Nov 15, 2010
    Thanks for your mesage...we tried a new chain and it didn't help any.
    Genius:
  • 1,015 Answers
I would say that it's time for a new chain. After using for varying periods of time the chain will stretch too far to be used anymore. This is caused by heating during usage. Some things that will cotribute to chain wear out are insufficient bar oil, dull chain or just every day wear. I think if you get anew chain you'll be fine. When I'm tensioning my chains I run the saw at high rpm for a couple of mins. Shut off and grasp chain by mid-point of bar and lift up. I try to get enough space to slip a nickle between bar and bottom of chain. You should check tension often, as over tightening also adds to wear on chain and motor. Hope this helps you. Thanks
Posted on Nov 14, 2010
  • Jack Spooner Nov 15, 2010
    If your new chain didn't help then the only other thing I can think of is that your tensioner gear or screw is stripped out. Sorry I couldn't be of more help. Thanks.
How much pressure can you put on a 1-1/4" band saw blade?
Check out this article and this link for you to better understand the bandsaw blade tensioning. You may want to read this blog too. http://bandsawblog.com/blade-tension/ .
Feb 27, 2013 | Saws
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
My saw blade isnt moving up and down. The jig saw sounds like its running just the blade isnt moving at all..... how do i fix it?
Unplug and Take the case apart. You will probably see that the gear moving the blade collet is stripped. Or, the gear fell out of place. Try putting it back together and see if it works.
Jul 08, 2011 | Saws
I have powermatic pm2000 3hp 10" saw, when I try to turn on push on button , it blows the breaker. I have correct power. I have used this saw for 5 years no problems. I took magnetic switch apart,...
There is a direct short some where.Unplug and turn the blade and listen to the bearings. One of the brushes might be worn down and be jammed against the armature. Five years of use and those brushes might be ready for replacement. If things turn out to be easy fix then changing brushes is not that hard.When you take them out you will see some small holes in the holders.When you put the new brush in the spring will try to push the brush back out,use a small piece of wire in the holes to hold it in.Next install the brushes back where they go.Check the armature out use a hacksaw blade to clean those grooves between the metal strips.Put the armature back in place and button it back together and pull out the keeper wires and your done.
May 08, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
How to change blades
unplug it. remove the bolt in the center of the blade. the blade will slip off then. a wrench for this should have come with your saw. if not, use any properly sized wrench. if needed, pull back the blade guard, put the blade on a old piece of wood, push down on the saw and use the wrench. the wood and your pressure will stop the blade from turning as you loosen the bolt
Feb 12, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a Bosch jig saw that I am having trouble getting blades in; I took the saw apart and now I can't get the saw back together. Help
You can try to get a breakdown at Boschtools.com but you will need the exact model number and on the left side there is a link to download a breakdown. Let me know if you need more help and I will try and if I have answered your question would you please rate this response accordingly.
Sep 28, 2009 | Bosch Saws
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
After reassembly blade will not cut wood, does not maintain suffient tension despite being correctly inserted
It sounds like the blade is not going through the guides properly if the blade is being pushed away from the wood.
Your blade is facing and moving the right direction, I am assuming.
Apr 17, 2009 | Saws
Changed delta saw blade
it turns the other way, to the right!
Oct 18, 2008 | Saws
Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
