Question about PANDIGITAL Panscn02 Photolink Scanner
We have lost the cleaning items listed as necessary to clean our photo scanner. Is there something else that we can substitute, or a way to procure the items listed in the user guide? Thanks so much, Vicki Arnold
  • vickiarnold Nov 14, 2010
    Taran, our scanner does not have a glass surface, so your solution will not work for us. It is a scanner that you slide the picture through, i.e. we cannot access the internal parts. Our scanned pictures save with lines across them now. Definitely needs cleaning. The user guide specifically states NOT to use alcohol. Please help. Vicki
  • vickiarnold Nov 17, 2010
    I am not happy with this solution, Taran. It does NOT work for my scanner, which is the one pictured above. I feel like I wasted $12 on this!! Vicki
  • 8,197 Answers
Hi.
The only way to get the cleaning parts for the scanner is to contact Pandigital on the link below. Sorry they are closed today but they will be open tomorrow from 10am to 7pm PST.
http://www.pandigital.net/contact.html
Good Luck
Posted on Nov 14, 2010
  • 10,515 Answers
You could also use a soft, lintfree, cloth moistened with isopropyl alcohol or household glass cleaner to clean the scanner glass surface.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Error Epson Stylus Photo PX660 - Close the Scanner Unit
maybe the scanner rail of scanner has been stuck that's why when you turn on your printer there's an error!!! or if you can try to open the scanner and clean the motor and the belt.
it might dirt or something that causing your printer to turn it on or causes-sing error.
for my opinion plss.. check the scanner we have desame cases in my printer too. I open the scanner and clean it then it works..
Apr 27, 2014 | Epson RX595 Photo All-In-One Printer
How do I delete photos off of the card after I have saved them to my computer?
If you have connected the scanner .... using the mini-USB port at the back of the scanner ... to your PC, and you have already downloaded (copied) the photo directly off the card to your computer ... you can select the photo's (on the card) that you do not want (e.g. click on the item / icon list) ... and press DELETE ... like you're deleting a file off one of your folders/directories. You will be shown a pop-up window asking you to confirm if you really want to delete those (selected) files (photos). Click on YES.
Yes, the PC sees the contents of the card as a "list" of files in the (card) folder. So, just delete the photo's (files in the card) folder like you would delete any file.
If you have the card (removed from the back of the scanner) and inserted into your PC (e.g. via a USB card reader) ... and you have already (selected and) copied the photos (files) to your computer, you can do the same (as above) to delete the photos off the card. That is, select the photo's you want to delete (by clicking on the icon or item listed) and press the DELETE key.
Nov 04, 2013 | PANDIGITAL PhotoLink Office Equipment &...
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Visioneer Strobe XP 100 - Vertical lines on photos
I lost my software Driver of Flatbed scanner D1250u2f. So, I want to download a new for my scanner. Where Can I get it; can you help for getting it.
Feb 07, 2009 | Visioneer XP100 Strobe Mobile Scanner USB
Scanner coloring doc.
in your printer menu there should be a option for cleaning the printer heads. if not you need to remove the cartrages and clean yourself with rubbing alcohol. also clean off the cartrages also.this should get rid of the saturation problem.let me know if this helped.
Dec 22, 2008 | Epson Perfection 1260 Photo Flatbed...
Poor quality scan? Tips for cleaning this device
You can clean the scanner glass with warm water and a dust free cloth. Is the line always in the same spot in your scans? Could be something else other then dirty glass.
Aug 26, 2008 | Lexmark X1240 All-In-One InkJet Printer
How to change startup
its very very easy. down load ccleaner for free its a software which allows you to clean up all files which are not necessary, cleans registry and you can choose startup items which ones to start and make booting process faster
www.ccleaner.com
Jul 30, 2008 | Toshiba Satellite A85-S107 Notebook
New cooktop. spilled food how to I clean it up
I need more information. Smoothtop? Gas? Electric? Stainless steel? Smoothtop, scrape what you can off with a plastic credit card or something similar. If necessary use a razor blade. Finish cleaning with a liquit polishing top cleaner made for smooth top ranges. Regular use will leave a smooth finish that will make it easier to clean. Us only a plastic pad or other non abrasives. Regular porcelain top. clean up as best you can with a dish rag. scrape with a plastic tool. Use oven cleaner if necessary. Don't get oven cleaner on painted or aluminum items. It will remove numbers, writing etc and badly stain aluminum.
Jul 08, 2008 | Whirlpool Kitchen Ranges
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
PANDIGITAL Panscn02 Photolink Scanner Logo
251 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
