Question about Dell Dimension 5100 (D51L1) PC Desktop
On booting up my Dell 5100 an error message comes up as follows: Error allocating I/O bar for PCI device. The computers locks up at the XP startup page
    Brigadier General:
  • 8,909 Answers
The computer needs the PCI slots to be enabled as they are used in communication from processor to most periferals.
It sounds like the mother board drivers are not installed or have corrupted some how.
Run the motherboard driver disk and reinstall the drivers. They can be downloaded from the mother board manufacturers web site.
You may need to burn them to a cd with a bootable system in dos, to run them.
Hope that helps.
Posted on Nov 14, 2010
Testimonial: "Thanks so much. I will try your solution."
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell computer e 310
its usually bihind the main hard drive in this model it easy to check any way!
Oct 28, 2009 | Computers & Internet
Can't boot up
reformat it using Windows XP SP2
Feb 15, 2009 | Acer Aspire 5100 Notebook
PCI device.
An “Error allocating Mem Bar for PCI device” suggests that a card located in one of your PCI slots has a possible problem. Try removing the card, (or cards-one at a time) to eliminate the error. Here’s a link showing location of PCI slots: http://support.dell.com/support/edocs/systems/dim3000/en/SM/techov.htm#wp1061217
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 14, 2009 | Dell Dimension 3000 PC Desktop
1802 PCI error & Resource Allocation Failure
Hi disable the resource allocation to S3 first and then add the Nvidia card . A jumper could do this - for disabling onboard graphics .
May 04, 2008 | IBM eserver xSeries 360 8686
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Dell Dimension 5100 (D51L1) PC Desktop Logo
249 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
