Question about Acer Aspire 5315 Notebook
Where are internal batteries? - Acer Aspire 5315 Notebook
    Brigadier General:
  • 8,909 Answers
Hope that helps.
Posted on Nov 14, 2010
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Time setting on camera is lost every time i turn off ,changed battery, with correct one
The internal battery is depleted. In some cameras it will charge off of the removable battery after several hours, if the internal battery is still good. Otherwise you must replace the internal battery which is a watch type battery.
Mar 09, 2015 | Cameras
Kodak m1063 not holding date and time
There is an internal battery in most cameras that is charged by the Lithium Ion battery when the camera is in use. If the camera is being used and the Lithium Ion battery is fully charged and yet the time/date is not being stored then there is probably a problem with the internal battery
Sep 15, 2014 | Kodak EASYSHARE M1063 Digital Camera
My internal battery is depleted. how do i change
Do you meant Korg M1 ?
How to replace Korg M1 internal battery, read HERE
FixYa can only give you the guide requested but for DIY, you are responsible for your own repairs.
Jul 24, 2010 | Korg TR76 76 Key Synthesizer Workstation
Canon sd750 does not hold date/time setting
yes there is a internal battery the camera has to be opened up to replace it. we replace the battery on this model for 45.00
Jan 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
How to take out internal battery?
The internal battery is located under the cover for the AA batteries compartment.  The internal battery holder is located next to the middle battery of the line of three batteries.  The end of the holder has the internal battery size printed on it (CR 1220).
Jul 03, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot G6 Stopped Working
no, there is not an internal battery in canon g6 for operating it.
probably the battery does not touch the internal connectors of the camera.
May 10, 2008 | Canon PowerShot G6 Digital Camera
Date/Time problem
Hi all, same problem happened also with my S304. I' ve deassembled it and there IS an internal battery on one of the pcb's inside. So, i'm sure that if this is replaced by a new one, this problem should be fixed. Replacement will be a little bit tricky as the battery is soldered internally. If i have found the right type of battery, i'll post it, but this can take a little time ;-) F
Apr 23, 2007 | Fuji FinePix S304 Digital Camera
Acer Aspire 5315 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
