Question about Philips Magnavox DVD/VCR Dual Player
VCR playback issues
The VCR component of my machine will only play back tapes that it recorded itself. it's the weirdest damn thing. I can record programs and watch them perfectly fine, but if I put in a commercial pre-recorded tape, it plays the picture for about 2 seconds, then stops itself. it has similar trouble when I pop in a tape that was recorded by a different VCR.
it's not a connection problem, because DVD, television channels and tapes that *will* play come out just fine. and obvioulsy it's not even that the VCR doesn't work at all, so we're just stumped about why it's selectively rejecting tapes.
  • meltem09 Jun 18, 2008
    thank you! I'm going to repost because a VCR with that problem might have a different cause than a DVD player (er, just by logic...I don't know much about electronics)
    leethedeuce, it doesn't actually eject the tape. instead, the video cuts out and leaves me with that blue screen. the tape stays in the vcr.
    Master:
  • 638 Answers
It is the tape led that creating this problem . it requires proper alignment of the lens.u will hve to get it done by technician.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Posted on Jun 18, 2008
    Genius:
  • 1,036 Answers
Hi there.
It's deffinately missalignment of the tape head.
Was it dropped at all - or moved?
Worldvet has a solution, but a simpler method may be to GENTLY pull on the read spool assembly.
In theory, the problem was cause by inertia causing the tape head to drop, this may be aleviated by moving the reader up.
The question is - by how much? Trial and error running the thing on the bench with a pre recorded tape untill you get a good signal.
Please be careful when working with live equipment. If in any doubt, use an experienced technician.
    Genius:
  • 1,665 Answers
  • 487 Answers
Ok this is actually a comon problem. The heads are not alighned right. Which will make recording and play back not a problem but other videotapes won't play because the tracks are off in regards to the heads.
If you are patient you can adjust the heads yourself but otherwise a video shop can have that done in 5 minutes.
    Guru:
  • 859 Answers
This is a common issue with VCRs. Your situation is not unusual and has to do with the tracking. Most VCRs won't allow you to manually adjust tracking anymore and rely on automatic tracking. Unfortunately this means your VCR has to read the very bottom of the tape correctly to get the tracking data information. When the alignment path on your machine is off as much as it is, you will have this issue.
This can be resolved by adjusting the tape path height inside the VCR. But, do not attempt to adjust the tracking head height while in playback, you will damage the head as it is hunting for the tracking data path. You have to make each adjustment and then insert the tape from another source and notice the changes. What you do is move the tracking path head downward incrementally so you can read your tapes and tapes from another source. You can find the tape path schematic for your model by using Google.
Hope this gets you headed in the right direction but I'm not certain you will be happy with the results.
Regards,
Worldvet
  • 4,472 Answers
Hard to say without seeing it but it may be the LED under the prism in the middle of the circuit board, it is a common problem on philips VCRs. After it ejects the tape does it try to pull the carriage back down?
  • Lee A.
    Lee A. Jun 18, 2008
    Yes most likely you will need to have the heads and led aligned. As this will most likely cost you around what new unit is. I would just replace it. You can pick dual dvd/vcr decks for fairly cheap. If you need anything else let me know.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    I'm sorry did you not find this helpful at all? If not how can I assist you further?
    Thanks,
    Lee
    Genius:
  • 2,028 Answers
I had a similar issue with a DVD player, in that it wouldn't play any commercial or rental DVD's, but it would play them if I burned a copy on my laptop. Turned out to be board inside the machine. I had to replace it.
  • Ryan Rogers
    Ryan Rogers Jun 18, 2008
    Sorry I didn't mention that it was a DVD/VCR combo. The VCR end didn't work either.
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | JVC HR-J461MS VHS VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Playback is speeded up on taped recorded at SLP Symphonic VCR SE 226D
buy a new damn vcr o ya We r in the 21st century we now use dvd's go get ya self a dvd player abd you wont have that problem.
Dec 10, 2007 | Televison & Video
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Philips Magnavox DVD/VCR Dual Player Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
